Dreamweaver F12 Preview in Browser with XAMPP Virtualhosts
Thread begun 1/09/2014 1:38 pm by Kevin373660 | Last modified 1/10/2014 8:12 am by Jason Byrnes | 6308 views | 3 replies |
Kevin373660
CONFIGURED:
Windows XP Pro
Windows Explorer 8
FireFox
Dreamweaver CS3
Installed: XAMPP Windows 1.8.1
Apache 2.4.7
PHP 5.4.7
I have tried to modify the appropriate files to utilize virtual localhosts from my test server. With Apache started (running) the following pages display in browser when URL is typed in to the address bar of the internet browser (Internet Explorer or FireFox).:
http://localhost/xampp/ -displays Xampp Configuration Window
http://localhost/xampp/yourdomainname/ -displays home index.html page
From the home page displayed in the browser, I can navigate through the localhost website: html, php, and txt pages. No Favicon displayed.
PROBLEM
However, from within Dreamweaver with webpage open, I cannot successfully Preview the page in the web browser (Internet Explorer or FireFox). The following message appears:
Internet Explorer cannot display the webpage
The browser address bar displays: http://loalhost/yourdomainname/testpage.php
I tried turning off the antivirus and firewall protection but this did not seem to help. This would indicate to me that some setting in the browser may be blocking displaying the page.
The Webassist tutorials are clear to install Xampp. But support documents and internet examples that I have read but do not go into detail about configurations or are conflicting.
Should the Preview from Dreamweaver work? Or is this to be expected? What configuration changes do I need to try?
by default, xamp should be installed ton the c drive at:
c:/xampp
for this address to work:
the files should be at:
c:/xampp/yourdomainname/
in your site settings in dreamweaver the first step is to set the local files location, set the local files to be saved at:
in the testing server section, use the local path:
and the Web URL:
most likely what is happening is that you have the local path to another location, or the testing server path to another location.
if the local path is to another location, the files need to be put before browsing to them
if the testing server path is to another location, that wont map with how xampp is configured.
Kevin373660
Jason,
Thank you for the fast reply. I have the Dreamweaver F12 Preview in browser working.
I followed your path logic and found that I had not corrected the hosts file correctly and accidently saved as a .txt file format.
I agree that in a standalone test web server environment the default install address is fine. However, I have several websites to work with and for security reasons I have installed Xampp on a different directory/partition.
The most resent Xampp now automatically detects the install directory and adjusts relavent code during installation, recommending that separate domains be install under in their separate site specific folder under the \htdocs directory.
X:\xampp\htdocs\yourdomainname1
EDIT: C:\WINDOWS\system32\drivers\etc\hosts
127.0.0.1 localhost
127.0.0.1 loopback
127.0.0.1 yourdomainname1
EDIT: httpd-vhosts.config
NameVirtualHost *:80
<VirtualHost *:80>
DocumentRoot "X:/xampp/htdocs"
ServerName localhost
</VirtualHost>
<VirtualHost *:80>
DocumentRoot "X:/xampp/htdocs/yourdomainname1"
ServerName yourdomainname1.localhost
<Directory "X:/xampp/htdocs/yourdomainname1">
Options Indexes FollowSymLinks
Order allow,deny
Allow from all
Require all granted
</Directory>
</VirtualHost>
ok, glad to hear it is working
