Page Reload issue
Thread begun 1/08/2014 3:45 pm by hbibizadeh396670 | Last modified 1/09/2014 9:56 am by Jason Byrnes | 2170 views | 5 replies |
hbibizadeh396670
Page Reload issue
I have a simple comment system on my page using the data assist insert.
The issue is that when the comment is posted, the comment will not appear until the page is refreshed.
When the page reloads it posts the comment 2 times for some reason
I have tried to play with settings, but the product wont seem to apply the code and nothing changes even if I direct the page to another.. I just reloads the same page..
Please let me know if i haven't explained my issue
move the upload and update code at lines 323 - 362
WA_DFP_SetupDownloadStatusStruct("WA_DownloadResult1");
if(isset($_POST["DownloadFileButton"]) || isset($_POST["DownloadFileButton_x"])){
WA_DFP_DownloadFile("WA_DownloadResult1", "../Forum-SharedFiles/", "".$row_Post['ShareFile'] ."", "[FileName]", false, false, false, "", "", "", "");
<?php require_once("webassist/email/mail_php.php"); ?>
<?php require_once("webassist/email/mailformatting_php.php"); ?>
// WA DataAssist Insert
if (isset($_POST["CommentButton"]) || isset($_POST["CommentButton_x"])) // Trigger
$WA_connection = $Connection;
$WA_table = "siteezy_comments";
$WA_sessionName = "LatestComment";
$WA_redirectURL = "Post.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = true;
$WA_fieldNamesStr = "MessageID|UserEmail|UserName|Comment";
$WA_fieldValuesStr = "".$row_Post['MessageID'] ."" . $WA_AB_Split . "".$row_User['UserEmail'] ."" . $WA_AB_Split . "".$row_User['UserFirstName'] ." ".$row_User['UserLastName'] ."" . $WA_AB_Split . "".((isset($_POST["Comment"]))?$_POST["Comment"]:"") ."";
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_connectionDB = $database_Connection;
@session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
if ($WA_redirectURL != "") {
$WA_redirectURL = str_replace("[Insert_ID]",$_SESSION[$WA_sessionName],$WA_redirectURL);
to 219 so it is before the recordset code.
hbibizadeh396670
Thank you for the reply.
However, I moved the code (Please see file), but now the comments dont post at all..
Not Sure what is going on on the page?
in the upload and the update behavior, you are using a few fields from the recordsets on the page.
instead, create hidden fields, bind the hidden the recordset values, and in the upload and update behaviors use the hidden field bindings instead of the recordset bindings.
Hers a basic description of what was going wrong:
First the code order was such that the Recordset was cerated, before the data in the database was updated. SAo the recordset would contain the original data.
to make it so the recordset can contain the updated information, the update needs to occur before the recordset is created.
the problem with that, is that the recordset doesn't exist while the update is occurring, but you are trying to use data from it in the update. this is causing the update to fail.
hbibizadeh396670
Fantastic.. yes that fixed it... thanks again
you're welcome.
