Can't connect to database on server - error message when trying to test connection.
Thread begun 1/07/2014 7:04 am by sandy170299 | Last modified 1/08/2014 11:05 am by Jason Byrnes | 5123 views | 18 replies |
sandy170299
I have checked the connection string, and all is good. I am attaching the error message when I test the connection, and the URL that is entered into my server setup in Dreamweaver.
sandy170299
p.s. the testing server and the remote server ARE the same...
the web url should be:
http://38.111.52.37/
sandy170299
Jason, that didn't change anything. I'm still getting the same error when testing the connection string.
is there anything uploaded to the site?
using the address:
in a browser redirects to a pearl script. does the site have a vlid domain use? use that instead.
the web URL in the testing server settings needs to be a valid URL To the root of your site.
sandy170299
It's a temporary URL until the domain transfers, which it has not yet. Will it not with without the domain?
It may not work with the temporary domain.
send a screen shot showing the current error, it should have changed al be it slightly and the current testing server settings.
sandy170299
No need for a screen shot. All it says now is "An unidentified error has occurred." That's it - nothing more.
In your replay you said it didn't change anything and that it was still the same error message, that's not the same error from you initial report. seams something did change, no?
when it tries to test the connection it will try to upload a file to the site:
_mmServerScripts/MMHTTPDB.php
then access that file using:
<URL Prefix>/_mmServerScripts/MMHTTPDB.php
the unidentified error message means that it cannot access that file using the address specified in the URL prefix.
it amy not work till there is a domain name.
sandy170299
Right - the first time I tried the connection after the change, I got the same message as before. When I tried it again, I got the one I just posted. Okay - I will work on getting the domain transferred, and maybe that will help. Thanks!
