edit update removes some styling
Thread begun 1/07/2014 5:17 am by Jamie | Last modified 1/07/2014 8:10 am by Jason Byrnes | 2473 views | 7 replies |
Jamie
Hi Jason
Have inherited a website in which the main content area was created using tables. The client doesnt have the time or money to change this setup so have just added a CMS so that they can edit the content themselves.
The problem is that if they go to edit an entry, when they click on update, the update is causing certain elements to be removed from the styling thus throwing off the whol epage. For example,
<td valign="top" width="50%"> gets changed to <td>
<div align="left"> gets changed to <div>
<ul class="fade slideshow"> gets changed to <ul>
Is there anyway I can stop this happening please?
Cheers
Jamie
in the webassist/ckeditor/config.js file add :
config.allowedContent=true;
to the CKEDITOR.editorConfig = function( config ) { array
Jamie
Thanks Jason, Have changed the file as follows:
* @license Copyright (c) 2003-2013, CKSource - Frederico Knabben. All rights reserved.
* For licensing, see LICENSE.html or http://ckeditor.com/license
// Define changes to default configuration here. For example:
// config.language = 'fr';
// config.uiColor = '#AADC6E';
Unfortunately it is still editing the code on update...
did you clear the browsers cache?
Jamie
Yes I did clear the cache with no effect... I also tried 2 different browsers that hadnt been used to access the site in the first place.
See pm for further info requested
in the config file:
was supposed to be:
Jamie
ahh thats done the trick - was it the order and the array in their or just the array?
order and the array, both
