Adding a alert message.
Thread begun 1/06/2014 5:38 pm by gary917 | Last modified 1/08/2014 11:49 am by Jason Byrnes | 4897 views | 13 replies |
gary917
Hi I have a long form and have found that some users think they have filled out the form correctly when they have not. Because of the length of the form they are missing some of the error messages that are appearing at the top of the form. Can you suggest away that I can prevent this from happening? I was thinking of generating a popup message to alert the user that alerts the user of the form may not be filled in correctly. But I am unsure how to generate this message. Thanks
spry validation does not offer a way to open an alert on validation fail.
you could add an onclick event to the submit button to scroll to the top:
onclick="window.scrollTo(0, 0);"
this may help some but not if the errors are in the middle of the page.
gary917
Possible with addition
Instead of an alert message would it be possible do what you suggested along with opening a div at the top of the page using something like...
<?php if(isset($_GET['sent']) && $_GET['sent'] == "false") { ?>
<div class="confirm">Please check your forms for errors.</div>
<?php } ?>
sure, but dont add the if statement around the div, and add a style to set it to hidden by default:
<style type="text/css">
.confirm { display: none; }
</style>
<div class="confirm" id="confirm">Please check your forms for errors.</div>
then use this for the onclick:
onclick="window.scrollTo(0, 0);document.getElementById('confirm').style.display = 'block';"
gary917
type="submit"
This script is not working, I think it is because I am using the type="submit" instead of type="button". In full I am using the following for the form button action...
<input class="formButton" name="TZAuto_submit" type="submit" id="TZAuto_submit" value="Contact me" onclick="window.scrollTo(0, 0); document.getElementById('confirm').style.display = 'block'; clearAllServerErrors('TZAuto_TZContact_TZContact')" tabindex="40" />
Can you suggest away to fix this?
i need a link to see the problem and copy of the page to see the code in context.
gary917
Link and Code
I have provided the link and the code in the private message section.
1) the link you sent is for the message sent page not the form page.
2) instead of pasting the code from the page in your message, it is better to compress the original php page to a zip archive and attach the zip file.
3) the confirm div is inside an message span:
<span class="emailFormError"><div class="confirm" id="confirm">Please check your forms for errors.</div></span></div>
remove the span tag.
gary917
Sorry about that
Here is the correct link and the compressed file. I have removed the span tag from the page but it did not change the functioning of the page.
try changing onclick to onmousedown:
onmousedown="window.scrollTo(0, 0);document.getElementById('confirm').style.display = 'block';clearAllServerErrors('TZAuto_TZContact_TZContact')"
