What tool or combination of tools to use to build a form with image upload?
Thread begun 1/02/2014 3:35 pm by FPhu61701534 | Last modified 1/07/2014 7:14 pm by FPhu61701534 | 5082 views | 18 replies |
FPhu61701534
I would like to build a form that allows the user to upload one or more photos together with their bio data. Can this be done with DataAssist only or do I need other tools like Digital FilePro? What is the workflow?
Data Bridge contains the functionality of Digital File pro and Data Assist. See this tutorial for details on adding file upload data bridge insert and update pages:
http://www.webassist.com/tutorials/Add-file-fields-to-Data-Bridge-insert-update-pages
FPhu61701534
Another thing, after the user has uploaded the image to the database, is it possible to send a copy of the image via email on form submits?
I tried following the steps in the tutorial at the link you provided. I am lost! Do I need to create a database table since I have to use Insert Record? Is there a video on this?
you mention that the form is going to be used to enter Bio Data, so I assumed this would be stored in a Database. It does not _have_ to be, but if you wish to use the info on other pages of the site, then yes, you would need a database table.
if you only wish to send the uploaded file and bio information through an email, then no you don't need as database. In that case it is a simple mater of creating a form, and adding the Universal Email behavior. In Universal Email there is a section to set the attachments.
if you want to send the email, and save the information to a database, you need to use the insert behavior, the upload file behavior, and the Universal Email behavior.
It's a little difficult to give specific answers, which you seam to be looking for, when the question does not include enough detail.
the topic "file upload" can fit any number of use cases.
FPhu61701534
I created a very simple image upload page but it fails to work.
the upload helper file that should be here:
webassist/file_manipulation/helperphp.php
is returning a 404 page not found error message meaning it does not exist on the server.
make sure to upload the webassist/ folder to the server.
FPhu61701534
Ok. I have uploaded the webassist folder. There is no more error message. However, no image is uploaded to the designated folder. See my private message for the hosting engineer's reply.
One issue i see is that you have bound the fi;le name setting to the Server File name binding that is created by the upload.
this is circular logic. you cant use the server file name variable for the file name setting since the file has not yet been created on the server.
the server file is a variable created by the upload after the file has been created on the server using any renaming settings you have set. In your case, you have set the if file exists to over write the existing file, but if you had selected to rename the new one with an increment value, this would need to get added to the files name.
in the upload settings, for the file name, you should leave the default value:
[FileName]
this will use the original file name when it saved the file on the server.
to trouble the file upload, make the following changes:
1) add the following code at line 1 to turn on error reporting:
error_reporting
(E_ALL);
2) add the following before the </body> tag:
<pre><?php var_dump($_FILES); ?></pre>
3) place you cursor in the body of the page, open the bindings panel, expand the WA UPloaded Files Global Status collection, select the Debug Info binding and click the Bind button at the bottom of the binding panel to add the debug info to your page.
once these changes are made, let me know and i will test the page to see the result and determine how to proceed.
FPhu61701534
I still can't find the image in the \photos\ folder. The debug results as follow:
Status object: WA_UploadResult1
statusCode : 1
errorMessage :
clientFileName : 767A4948_mobi.jpg
fileExtension : jpg
serverFileName : 767A4948_mobi_2.jpg
serverSimpleFileName : 767A4948_mobi_2
serverDirectory : \photos\
contentType : image/jpeg
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed : 1
fileSize : 646725
isImage : 1
imageWidth : 1024
imageHeight : 1024
WA_UploadResult1_1:
fileExtension : jpg
fileSize : 646725
imageWidth : 1024
imageHeight : 1024
isImage : 1
fileWasSkipped :
fileWasRenamed : 1
statusCode : 1
array(1) {
["txt_photoupload"]=>
array(5) {
["name"]=>
string(17) "767A4948_mobi.jpg"
["type"]=>
string(10) "image/jpeg"
["tmp_name"]=>
string(29) "C:\php\uploadtemp\php7DAD.tmp"
["error"]=>
int(0)
["size"]=>
int(646725)
FPhu61701534
This is the hosting provider's reply (see private message).
