Issue when Inserting or Updating a new product using GoDaddy hosting with Power Store 4
Thread begun 1/02/2014 11:09 am by Jason Byrnes | Last modified 3/24/2015 11:07 am by Jason Byrnes | 9954 views | 8 replies |
Recently GoDaddy has implemented mod security on there PHP servers. This change is causing the Products insert and products update pages of Power Store 4 to fail with an error saying the server unexpectadly droped the connection.
In Safari, the error may look like:
  Safari can't open the page "http://www.yourdomain.com/admin/products_insert.php" because the server unexpectedly dropped the connection. This sometimes occurs when the server is busy. Wait for a few minutes, and then try again.
In Fire Fox:
  The connection was reset
The connection to the server was reset while the page was loading.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer's network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
Attached are updated copies of the power store admin/products_insert.php and admin/products/update.php file to correct the problem.
UPDATE: This effects the Installation of new Power Store sites also. Attached is a copy of the install/database.php file to fix that problem.
Web Designer Troy
Similar Mod_Security Problem with DataAssist
I'm having a similar problem with GoDaddy regarding mod_security. When I try to inject data into the database, I receive attached error.
GoDaddy told me that I was creating to many posts within some time frame. I narrowed down whatever is causing the security issue to the php script above <head>.
I would like to know what you changed in or around the "Insert" script to resolve the issue with Power Store.
see PM
Web Designer Troy
Similar Mod_Security Problem with DataAssist (2)
I found out the problem. Codes that are triggering the security are things like:
<input>
javascript:void();
I'm being prevented from injecting these common codes into the database. It limits the use of the HTML Editor among things. Nothing I can do about it.
the mod security addon is trying to prevent SQL injection by flagging the insert of javascript to the database. maybe if you had a dedicated hosting account you could have more control of the security settings. the only other workaround would be different hosting.
David
Connection at Install
I unzipped the 3 files, GoDaddyInstallFix.zip and GoDaddyProductsFix.zip
uploaded to my GoDaddy hosting in the same directory, and went through the Install , but I got the same result
This is an announcement thread, not a problem solving thread. Please start a new thread for this issue.
David
I don't understand when you reply
I don't know where is a Problem Solving thread;
Anyhow, after uploading to the server, I still have the same connection problem
You really should start a new thread for this rather than posting into this one.
you can start a new thread form here:
http://www.webassist.com/support/support.php
