Result page: do not show columns with no data
Thread begun 1/02/2014 10:26 am by ori382079 | Last modified 1/06/2014 6:16 am by ori382079 | 4408 views | 10 replies |
ori382079
Compliments of the season!
I have a result page with about 14 columns, but not all the columns will have data at any point in time. I was wondering how not to show the columns with no data. I have tried to use the Show Region if Recordset is not empty , but it does not seem to do it. Please advise. File attached
Use the show region tility.
select the recordset binding on your page. open the Server Behaviors panel. Click the plus button and select WebAssist -> Utilities -> Show Region
Click the lightning bolt next to If and select the corresponding column from your recordset. In the Is section, select the Not equal to option. leave the value field empty.
repeat this for each of the values shown on your page.
ori382079
RE: Result page: do not show columns with no data
Hi Jason, this is what I got after following your instruction:
SCREAM: Error suppression ignored for
( ! ) Notice: Undefined variable: row_WADAlcm_cases in C:\wamp\www\lcm_ng\lcm_cases_results.php on line 46
Call Stack
send a copy of the page please. I need to see the code in order to troubleshoot the error.
ori382079
The page is attached
theres no way the page you attached generates the error you report.
the error you report is happening at lin 46. in the page you attach, line 46 is:
there is no mention at line 46 of a variable named row_WADAlcm_cases.
please attach a copy of the page that produces the error you report.
ori382079
Morning Jason, The first page I attached contained the error but the last page attached had no error in question because I reverted back to original setup.Sorry for the mistake. Please I have implemented your original instruction on the same page and the error is now there. See the attached page
you put the show region around the recordset. ??it should be around the display of the recordset data in the page design.??In design view, select the code that displays the recordset information, for example:??<td class="WADAResultsTableCell"><?php echo($row_WADAlcm_cases['lcm_cp_id']); ?></td>??then add the show region utility.
ori382079
Thanks Jason, I tried it and it shows no data of columns with data. it returns no data and when I remove the show utility, the data are shown. Sorry to bother you
send a copy of the current version of the page.
I cannot answer questions about why the code is not working as expected without seeing the code....
