Applications:Adobe Dreamweaver CC:Configuration:Objects:Server:serverObjectsCommon.js
Thread begun 12/29/2013 11:50 am by jpvalls381558 | Last modified 5/27/2014 10:49 am by Jason Byrnes | 7392 views | 9 replies |
jpvalls381558
Hello,
I just bought Data Bridge, I installed it.
I have an error message on some server behavior of this extension.
Repeating Table, Html Editor CSS Buton DatePicker, in short I'm in a dead end and I do not know what to do.
Here is the message:
  Unable to open script file "Macintosh HH: Applications: Adobe Dreamweaver CC: Configuration: Objects: Server: serverObjectsCommon.js" (Error 2)
I said that I have the latest version of DW CC, I work on Mac OS 10.9.1
Deprecated Server Behaviors at Adobe is on DW CC before installing extensions, Data Bridge and Free Tools
During the installation of these extensions I had no error message.
Thank you for your help.
cordially
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
if you continue to have a problem, please post back details about the extensions and version numbers that are installed.
jpvalls381558
I did reset the workspace
I deleted the file: MacFileCache.dat
I read the post relating to the case : Forms
I copied the Forms folder, which was absent .
The following wizards work :
CCS Form , Cookie value , Html editor, file manager , css buton , captcha , datepicker , show if validation , image resizer .
Repeating table does not work
I still have this error message:
Or the error ( s) occurred following JavaScript :
Unable to open script file "Macintosh HD : Applications: Adobe Dreamweaver CC: Configuration : Objects: Server : serverObjectsCommon.js " (Error 2)
I did a search on my machine
Macintosh HD / Applications / Adobe Dreamweaver CC / Configuration / Objects / Server /
the file is missing
About Dynamic Web Wizard Insert Chart, I have a problem with the display because Flash Payer, it is installed on my machine but preview not working.
Do you have a solution , thanks for your help
Mac OS X 10.9.1
DW CC : Version > 13.2 Build 6466
Data Brigde : Version > 1.1.4
WebAssist Free Tools : > Version1.0.5
Deprecated Server Behaviors : > Version 1.0 .0
Regards,
JPierre
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
jpvalls381558
Hello
I'm a french user, I do not speak English, the messages that I post are translated by google.
My skype id jp74bond.
I am available Thursday, January 2nd from 9:00 pm French time.
Regards,
JPierre
see PM
Massimo
I have the same problem. Just try to reset my work area and copy form folder but the problem persist when I try to ad a sort behavior:
Dreamweaver
Si sono verificati i seguenti errori JavaScript:
Impossibile aprire il file di script "C:\Program Files (x86)\Adobe\Adobe Dreamweaver CC\Configuration\Objects\Server\serverObjectsCommon.js" (errore 3).
OK
What is your OS?
What version of Dreamweaver?
What extensions, including the version numbers are installed?
Massimo
Sorry! I had old version of db 1.1.8. Now I upgrade to 1.1.9 and all work fine.
glad to hear it is working.
