ecart checkout wizard javascript dreamweaver error code
Thread begun 12/24/2013 12:04 pm by henrik441511 | Last modified 12/27/2013 3:51 pm by Ray Borduin | 2039 views | 3 replies |
henrik441511
Hi
I have a lot of strange breakdowns with dreamweaver 6. (webassist-ecart-checkout wizard) Here i get this error so i can not continue building ecart.
Any idea to fix that?
The checkout wizard should be the easiest way to complete the entire checkout process. If you want to post your phone number in the private area of a reply to this thread I can look into it with you directly and figure out the cause of that error to get it working properly for you.
henrik441511
pm
That particular error appears to be associated with a corrupt xml file... WA_eCart/WA_DMCFG.xml
The ecart tries to store the design settings from your last application of the display manager.. that way the checkout wizard and displays added to other pages can automatically match. Somehow that file got corrupted and caused the error you are seeing.
Deleting that file and re-running the display manager should re-create the file and get around the error.
