redirect add to cart button
Thread began 12/22/2013 6:03 pm by Sam Barnhart | Last modified 3/14/2014 10:30 am by Jason Byrnes | 2888 views | 7 replies |
Sam Barnhart
The add to cart buttons have never redirected to any page. Once they are click, it just displays the same page. I would like them to go the the cart.php page. Ive searched the forum and tried a few suggestion but none work. Can anyone help. Seems like it should be simple but Im a novice at php. Thanks in advance.
Sam
Heres my code:
//WA eCart Include
require_once("WA_eCart/TotalCatECART_PHP.php");
<?php require_once('Connections/TTCStoreConnection.php'); ?>
$TotalCatECART->GetContent();
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
$maxRows_WADAproducts = 6;
$pageNum_WADAproducts = 0;
if (isset($_GET['pageNum_WADAproducts'])) {
$pageNum_WADAproducts = $_GET['pageNum_WADAproducts'];
$startRow_WADAproducts = $pageNum_WADAproducts * $maxRows_WADAproducts;
mysql_select_db($database_TTCStoreConnection, $TTCStoreConnection);
$query_WADAproducts = "SELECT ProductID, ProductSKU, ProductName, ProductPrice, ProductWeight, ProductCartDesc, ProductShortDesc, ProductLongDesc, ProductThumb, ProductImage, ProductCategoryID, ProductUpdateDate, ProductStock, ProductLive, ProductUnlimited, ProductLocation FROM products ORDER BY ProductID ASC";
$query_limit_WADAproducts = sprintf("%s LIMIT %d, %d", $query_WADAproducts, $startRow_WADAproducts, $maxRows_WADAproducts);
$WADAproducts = mysql_query($query_limit_WADAproducts, $TTCStoreConnection) or die(mysql_error());
$row_WADAproducts = mysql_fetch_assoc($WADAproducts);
if (isset($_GET['totalRows_WADAproducts'])) {
$totalRows_WADAproducts = $_GET['totalRows_WADAproducts'];
} else {
$all_WADAproducts = mysql_query($query_WADAproducts);
$totalRows_WADAproducts = mysql_num_rows($all_WADAproducts);
$totalPages_WADAproducts = ceil($totalRows_WADAproducts/$maxRows_WADAproducts)-1;
$queryString_WADAproducts = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_WADAproducts") == false &&
stristr($param, "totalRows_WADAproducts") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_WADAproducts = "&" . htmlentities(implode("&", $newParams));
$queryString_WADAproducts = sprintf("&totalRows_WADAproducts=%d%s", $totalRows_WADAproducts, $queryString_WADAproducts);
// WA eCart AddToCart
if (isset($_POST["TotalCatECART_1_ATC"]) || isset($_POST["TotalCatECART_1_ATC_x"])) {
$ATC_itemID = $_POST["TotalCatECART_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "";
$ATC_RedirectIfIn = "";
if (isset($totalRows_WADAproducts) && $totalRows_WADAproducts > 0) {
$row_WADAproducts = WAEC_findRecordMySQL($WADAproducts, "ProductID", $ATC_itemID);
if ($row_WADAproducts) {
$ATC_itemName = "".$row_WADAproducts['ProductName'] ."";// column binding
$ATC_itemDescription = "".$row_WADAproducts['ProductShortDesc'] ."";// column binding
$ATC_itemThumbnail = "".$row_WADAproducts['ProductThumb'] ."";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["TotalCatECART_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_WADAproducts['ProductPrice'] ."");// column binding
mysql_data_seek($WADAproducts, 0);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$TotalCatECART->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $TotalCatECART->redirStr == "") {
$TotalCatECART->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($TotalCatECART->redirStr != "") {
header("Location: ".$TotalCatECART->redirStr);
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"><!-- InstanceBegin template="/Templates/FirstPage Template.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
<!-- InstanceBeginEditable name="doctitle" -->
<title>Results products</title>
<link href="WA_DataAssist/styles/Refined_Granite Pine.css" rel="stylesheet" type="text/css" />
<link href="WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
<style type="text/css">
/* Title Section */
#WADAPageTitleArea {
width: 735px;
#WADAPageTitleArea div, #WADAPageTitleArea p {
font-size: 11px;
padding-bottom: 10px;
#WADAPageTitleArea div#WADAPageTitle, #WADAPageTitle {
font-size: 14px;
font-weight: bold;
.WADAResults {
font-size: 11px;
margin-top: 10px;
.WADAResultsNavigation {
border: 1px solid #BBC2C2;
padding: 2px;
height: 22px;
.WADAResultsCount {
padding-top: 4px;
text-align: right;
float: right;
#WADAResultsNavTop {
margin-left: 3px;
float: right;
.WADAResultsNavTable {
margin: 0px;
.WADAResultsNavTable td {}
.WADAResultsInsertButton {
margin-left: 3px;
float: right;
#WADAResultsTable {
margin-top: 10px;
margin-bottom: 10px;
.WADAResultsEntry {
.WADAResultThumbArea {
float: left;
.WADAResultInfoArea {
margin-left: 170px;
.WADAResultTitle {
font-size: 14px;
font-weight: bold;
.WADAResultDescription {
margin-top: 2px;
.WADAResultCommerceArea {
margin-top: 10px;
.WADAResultCommerceButton {
float: right;
.WADAResultPrice {
float: right;
font-size: 12pt;
.WADARecordNavigationButtons {
margin-top: 20px;
.WADAResultsBackTop {
float: left;
.WADAResultsCountBottom {
padding-top: 4px;
text-align: right;
float: right;
#WADAResultsNavBottom {
margin-left: 3px;
float: right;
.WADAResultPrice1 {
float: right;
font-size: 12pt;
</style>
<!--Start Google Verification-->
<meta name="google-site-verification" content="OLGH2aaT3VWVx2jNOY0t2xVU2kCiLtxvIKxG325xMts" />
<!--End Google Verification-->
<!--Start Google Analytics Tracking-->
var _gaq = _gaq || [];
_gaq.push(['_setAccount', 'UA-17381726-2']);
_gaq.push(['_trackPageview']);
(function() {
var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
</script>
<!--End Google Analytics Tracking-->
<!-- InstanceEndEditable -->
<link rel="stylesheet" href="ajxlightbox_Video%20R%20Nav%20Salmonella.css" type="text/css" />
<script src="ajxlightbox_Video%20R%20Nav%20Salmonella.js" type="text/javascript"></script>
<link href="style.css" rel="stylesheet" type="text/css" />
<link href="layout.css" rel="stylesheet" type="text/css" />
<!--[if lt IE 7]>
<script type="text/javascript" src="../js/ie_png.js"></script>
ie_png.fix('#logo');
</script>
<![endif]-->
<script src="js/jquery-1.4.2.js" type="text/javascript"></script>
<script src="js/cufon-yui.js" type="text/javascript"></script>
<script src="js/cufon-replace.js" type="text/javascript"></script>
<script src="js/RomanSerif_500.font.js" type="text/javascript"></script>
<script src="js/jquery.faded.js" type="text/javascript"></script>
.style1 {font-weight: bold}
.style2 {
font-size: 16px
</style>
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
(function() {
ga.src = ('https:' == document.location.protocol ? 'https://' : 'http://') + 'stats.g.doubleclick.net/dc.js';
</script>
<!-- ++++ Script for ShareThis Tag for Email START ++++ -->
<script type="text/javascript">var switchTo5x=true;</script>
<script type="text/javascript" src="http://w.sharethis.com/button/buttons.js"></script>
<script type="text/javascript">stLight.options({publisher: "94bbd555-34c4-439b-8b39-0a92b520ea99"});</script>
<!-- ++++ Script for ShareThis Tag for Email END ++++ -->
</head>
<body id="page1" onload="MM_preloadImages('plugins/images/Button_shopping_cart_RO.png')">
<div class="extra">
<div class="body1">
<div class="main">
<!--header -->
<div id="header">
<div class="wrapper">
<div class="Header_Logo_Div"><img src="images/Header%20Store%20Name.png" alt="" width="518" height="97" /></div>
<div id="Header_buttons_right_side">
<div style="float: left; height: 20px; width: 200px; ">
<!-- ++++ShareThis Tag for email START ++++ -->
<span class='st_email' style="float:left;"displayText='Share with A Friend' ></span>
<!-- ----ShareThis Tag for email END ---- -->
</div>
<a href="cart.php" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Cart Button','','plugins/images/Button_shopping_cart_RO.png',1)"><img src="images/Button_shopping_cart.png" width="160" style="margin-top:5px;" id="Cart Button" /></a>
<p>&nbsp;</p>
</div>
<div class="cleardiv"></div>
<div id="Nav_Header">
<h3><a href="index.php">Home / Product</a><img src="images/menu_line.png" alt="" width="20" height="20" class="nav_divider_spacing" /><a href="FAQ_Raw_Diet.html">Raw Diet FAQ</a><img src="images/menu_line.png" alt="" width="20" height="20" class="nav_divider_spacing" /><a href="Autoship_Program.html">Autoship Program</a><img src="images/menu_line.png" alt="" width="20" height="20" class="nav_divider_spacing" /><a href="resources.html">Helpful Links</a><img src="images/menu_line.png" alt="" width="20" height="20" class="nav_divider_spacing" /><a href="About_Us.html">About Us</a> <img src="images/menu_line.png" alt="" width="20" height="20" class="nav_divider_spacing" /><a href="contactus.html">Contact Us</a></h3>
</div></div>
<div class="wrapper_slideshow">
<!-- slider begin -->
<div id="faded">
<div class="rap">
<!--Place image code for slide show here START-->
<img src="images/img1.jpg" alt="" width="693" height="364" />
<img src="images/img2.jpg" alt="" width="693" height="364" />
<img src="images/img3.jpg" alt="" width="693" height="364" />
<img src="images/img4.jpg" alt="" width="693" height="364"/>
<img src="images/img5.jpg" alt="" width="693" height="364"/>
<!--Place image code for slide show here END-->
</div>
</div><!-- slider END -->
<ul id="banners">
<li id="banner1"><a href="benefits_of_a_Raw_Diet.html" class="style2">The BENEFITs<br />
OF A Fresh<br />
RAW Diet</a></li>
<li id="banner2"><a href="how_to_prepare_raw_food.html">HOW TO<br />
Prepare A<br />
Raw Diet</a></li>
<li id="banner3"><a href="why_choose_tcfeline_premix.html">WHY PICK <br />
TCFELINE<br />
Premix
</a></li>
</ul>
<!-- slider end -->
</div>
</div>
<!--header end-->
</div>
</div>
<div class="main">
<!--content -->
<div id="content"><!-- InstanceBeginEditable name="EditRegion1" -->
<div class="col2">
<div align="center" style="margin-bottom: 30px; border-bottom-color: #8EA972; border-bottom-style: dotted; border-right-width: thin;">
<p style="font-size:18pt; line-height:22pt; color:#C63;">Your Exclusive Feline Store providing Raw Cat Food Diets and
<br />
Whole Body Care
through a NaturalĀ and Holistic means.</p>
<p style="font-size:11pt; line-height:22pt; color:#C63;"><strong>Featuring TCfeline Premix... for a Quick, Easy &amp; Affordable Solution</strong></p>
<p style="font-size:11pt; line-height:12pt; color:#C63;"><strong>to making Homemade Raw Cat Food.</strong></p>
<p style="font-size:11pt; color:#555555;line-height: 8pt;">&nbsp;</p>
</div>
<div class="WADAResultsContainer"> <a name="top"></a>
<div id="WADAPageTitleArea" align="center" style="font-size:22px; line-height: 25px;"><span style="color:#000;"><strong>For help with issues placing orders, please call<br />
717 524-1949 or email info@thetotalcat.com.</strong></span><br />
<br /><strong>
We ship all orders the next day via USPS Priorty Mail! *</strong><br />
<p style=" font-size: 9pt; "><strong><a href="returnpolicy.html">SHIPPING RATES & POLICY</a></strong><div id="WADAPageTitle"></div>
</div>
<?php if ($totalRows_WADAproducts > 0) { // Show if recordset not empty ?>
<div class="WADAResults">
<div class="WADAResultsNavigation">
<div class="WADAClearRight"></div>
<div id="WADAResultsNavTop">
</div>
<div class="WADAResultsCount">Records
<?php echo ($startRow_WADAproducts + 1) ?>
to
<?php echo min($startRow_WADAproducts + $maxRows_WADAproducts, $totalRows_WADAproducts) ?>
of
<?php echo $totalRows_WADAproducts ?>
</div>
</div>
<table width="638" border="0" cellpadding="0" cellspacing="0" id="WADAResultsTable" >
<?php do { ?>
<tr>
<td class="WADAResultsEntry"><div class="WADAResultThumbArea"><a href="products_Detail.php?ProductID=<?php echo(rawurlencode($row_WADAproducts['ProductID'])); ?>" title=""><img src="images/images_thumb/<?php echo $row_WADAproducts["ProductThumb"]; ?>" alt="" width="150" border="0" class="WADAResultThumb" style="margin-bottom: 30px;" /></a></div>
<div class="WADAResultInfoArea">
<div class="WADAResultTitle"><a href="products_Detail.php?ProductID=<?php echo(rawurlencode($row_WADAproducts['ProductID'])); ?>"><?php echo $row_WADAproducts["ProductName"]; ?></a></div>
<div class="WADAResultDescription"><?php echo $row_WADAproducts["ProductShortDesc"]; ?> <a href="products_Detail.php?ProductID=<?php echo(rawurlencode($row_WADAproducts['ProductID'])); ?>">More...</a></div>
<div class="WADAResultCommerceArea">
<div class="WADAResultCommerceButton">
<div class="WADAClearBoth"></div>
<div class="WADAResultPrice"><span class="WADAResultPrice1"><?php echo $row_WADAproducts["ProductPrice"]; ?></span></div>
<form name="TotalCatECART_1_ATC_<?php echo $row_WADAproducts['ProductID']; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<p>
<input type="hidden" name="TotalCatECART_1_ID_Add" value="<?php echo $row_WADAproducts['ProductID']; ?>" >
<input type="text" name="TotalCatECART_1_Quantity_Add" value="0" size="7" style="float:right;" >
</p>
<input type="image" src="WA_eCart/Images/Granite Pine/Btn3_EN_addtocart.gif" border="0" class="eC_ImageButton" value="Add to Cart" name="TotalCatECART_1_ATC" style="float:right; margin:5px 0px;">
</form>
</div>
</div>
<div class="WADARecordNavigationButtons"></div>
</div></td>
</tr>
<?php } while ($row_WADAproducts = mysql_fetch_assoc($WADAproducts)); ?>
</table>
<div class="WADAResultsBackTop"><a href="#top" title="Back to top"><img border="0" name="Top" id="Top" alt="Back to top" src="WA_DataAssist/images/Granite Pine/Refined_up.gif" /></a></div>
<div class="WADAResultsCountBottom">Records
to
of
</div>
<div class="WADAClearBoth" ></div>
</div>
</div>
<?php } // Show if recordset not empty ?>
<?php if ($totalRows_WADAproducts == 0) { // Show if recordset empty ?>
<div class="WADANoResults">
<div class="WADANoResultsMessage">No results for your search</div>
</div>
<?php } // Show if recordset empty ?>
</div>
<div >
<p>&nbsp;</p>
<p style="font-size: 8pt; line-height:8pt; font-style:italic;">*Note: All orders are shipped out the next day (except Sundays) from our facility as long as the item is in stock and the all funds have been received for the entire order. In most cases, funds are received immediately if payment is via credit card or paypal. </p>
<p style="font-size: 8pt; line-height:8pt; font-style:italic;">&nbsp;</p>
</div>
</div>
</div>
<div class="col1">
<div class="box1">
<div class="wrapper" style="border-bottom:#bea97c medium dotted; margin-bottom:25px;">
<div style="border-bottom:#bea97c medium dotted; margin-bottom:25px;"> <p style="font-size: 11pt; line-height: 12pt;"><strong>Not sure about feeding raw or concerned about</strong></p>
<h1 style="font-size:16pt; line-height:20pt; color:#635C4B;padding: 0px; margin:0px;">Salmonella and Parasites </h1>
<p >with feeding a raw meat,<br/>
watch this video for answers.
</p>
<p>
<div class="AJXLightboxIQdRdXD_center_wrapper" style="margin-bottom:15px;">
<!-- AJXFILE:../ajxlightbox_Video%20R%20Nav%20Salmonella.css -->
<div class="AJXLightboxIQdRdXD">
<div class="AJXLightboxIQdRdXDli">
<div class="AJXLightboxIQdRdXDawrapper"><a title="Raw Meat Diet for Dogs and Cats" href="http://www.youtube.com/watch?v=G3wLTlqnMMg&amp;ajximg=http://i1.ytimg.com/vi/G3wLTlqnMMg/0.jpg" class="AJXLightboxa"><img src="http://i1.ytimg.com/vi/G3wLTlqnMMg/1.jpg" alt="Raw Meat Diet for Dogs and Cats" height="" width="165"/></a></p></div>
</div>
</div>
</div>
</div>
<h1 style="font-size: 25pt; line-height: 25pt;">OUr Promise to You...</h1>
<p><strong>To do the PRODUCT RESEARCH<br />
for you! To only offer quality product in our store.</strong> <a href="Guidelines_and_standards.html"><br />
Read More&gt;</a></p>
<p>&nbsp;</p>
</div>
<div class="wrapper" style="margin-top: 0px;">
<h1 style="font-size: 25pt; line-height: 25pt;">Feline<br />
Health<br />
Articles</h1>
<ul class="list1" >
<li> <a href="Articles.html">Urination Outsite Box</a> </li>
<li> <a href="Articles.html">CRF and Insufficieny</a> </li>
<li> <a href="Articles.html"><strong>Constipation</strong></a><strong></strong></li>
<li> <a href="Poison_List.html"><strong>Feline Poison List</strong></a><strong></strong></li>
</ul>
</div>
</div>
<div class="box2 marg_top1"><div class="wrapper">
<h1 style="font-size: 25pt; line-height: 25pt;">Success Stories...</h1>
<p >read stories from other Feline Owners on how a Raw Diet improved their Feline Companions health and life. </p>
<form id="form_1" action="" style="width:180px;">
<div>
<div class="wrapper"><a href="Share_Your_Story_Entries.html" class="button" ><span><span>Read the Stories</span></span></a></div>
</div>
</form>
<h1 style="font-size: 18pt; line-height: 18pt;">&nbsp;</h1>
<h1 style="font-size: 18pt; line-height: 18pt; border-top:thin #FFF dotted ; padding-top: 15px;">Share your Story...</h1>
<p>of how a raw diet improved your felines life.</p>
<div>
<div class="wrapper" style="margin-bottom: 0px;"><a href="Share_Your_Story_Form.html" class="button" ><span><span>Tell Your Story</span></span></a></div>
</div>
</form>
</div></div>
<div class="box3 marg_top1"><div class="wrapper" style="margin: 315px 0px 25px 0px">
<p style="color:#555; font-size: 11px; line-height: 12px;" ><em>- As owner of The Total Cat Store I only recommend products of quality, that I have researched personally and use myself, if applicable. I've been a Go Pet Plan client for over 4 yrs and choose GPP, after reviewing many, for their policy on cost, pre-existing conditions, coverage and re-imbursement. </em><em><a href="https://account.gopetplan.com/partner/totalcatstore">READ MORE</a>.</em></p>
</div></div>
<div class="box3 marg_top1" style="background-image:none; height:205px; padding-left: 0px;"><a href="http://feline-nutrition.org"><img src="images/Ad_Side_feline_nutrition.jpg" width="200" height="200" alt="RawFedKitty" longdesc="http://www.feline-nutrition.org" /></a></div>
</div>
</div>
<!--content end-->
</div>
<div class="bot">
<!--footer -->
<div id="footer">
<div id="Nav_Header" style="margin-top: 15px; float: left;">
</div>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p align="center">The Total Cat Store &copy;2011 &nbsp;|&nbsp; <a href="privacypolicy.html">Privacy</a> and<a href="termsandcondtions.html"> Terms and contiions</a> policy &nbsp;|&nbsp; <a href="returnpolicy.html">Return &amp; Shipping policy</a></p>
</div>
<!--footer end--></div>
</div>
<script type="text/javascript"> Cufon.now(); </script>
$(function(){
$("#faded").faded({
speed: 1200,
crossfade: true,
bigtarget: true,
autoplay: 4800,
autorestart: 1200,
autopagination: true
</script>
</body>
<!-- InstanceEnd --></html>
mysql_free_result($WADAproducts);
In the Add to cart button behavior, you don't have a go to after success page set.
Open the server behaviors panel. In the server behavors panel, double click the eCart Add To Cart Button server behavior.
on the general tab, click the folder icon Next to the Go To Page in the redirect section to select the page that should display after the item is added to the cart.
Sam Barnhart
Still need assistance
Jason, Hi.
I tried the instructions several times but with no luck in resolving the issue. When I add product to the cart, it just redirects me to the same page (same url) but no product is shown. And it does not add anything to the cart.
Can you help me with this issue and one other that still open (wrong description shown in cart
Sam Barnhart
Info request supplied in private message
Please see private message
See PM
Sam Barnhart
Providing contact info
See priv mess
We resolved this in a connect meetin, the root of the problems was the database connection.
