invalid JSON: MySQL server has gone away
Thread begun 12/20/2013 10:49 pm by info290144 | Last modified 1/01/2014 5:52 am by info290144 | 2778 views | 4 replies |
info290144
I'm in the middle of sending a newsletter using PowerMessenger but I get this error message: invalid JSON: MySQL server has gone away. Thia happens after sending only 82 email of 1134. It actually stops on 83.
What is the fix for this? Is there a way to pinpoint what email address is causing this problem?
Thank you for your help.
Please post your phone number in the private area of a response to this post. I'll give you a ring and we can look into what is causing this issue. I don't know offhand, but I'll be able to help track it down and get it fixed for you.
info290144
I was thinking of completely dropping the user data and re-importing it. Anything you want me to do before you call?
I was able to solve this problem... The issue has something to do with the length of time the SMTP server is spending sending that email.
I'm not sure why, but it took more than a minute to send to that particular email address. During that time the connection to the database timed out.
The solution that worked was to close the connection to the database before sending the email and then re-establish a connection once the mail was sent. This appears to have solved the problem.
info290144
Thanks. I had tried loging out of the system but it wasn't working. I'm glad it works now.
