How do you add keywords using a Power CMS content area?
Thread begun 12/19/2013 2:01 pm by sandy170299 | Last modified 12/19/2013 3:17 pm by sandy170299 | 4196 views | 12 replies |
sandy170299
When I do the following, <meta name="keywords" content="<?php echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'home', 'keywords'); ?>" />, all the keywords show up on the page, and they're not hidden. What am I doing wrong? Thank you.
sandy170299
I just noticed that there is an issue with the Title tag as well.
<title><?php echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'home', 'title'); ?></title>
When I use this, it outputs a bunch of garbage, and not the actual title of the page. I checked the CMS area and there is no special formatting on any of the content areas. I even copied and pasted it into notepad first, to make sure it was really clean.
send a link where i can see the problem please.
sandy170299
I can only leave it up for a short time, because the site is live.
http://northstarministorage.com/
Please let me know when you have viewed it so I can remove the code, before someone sees it!
sandy170299
I'm getting really weird code when I view the source.
<meta name="keywords" content="<div toolbar="inline default" rel="21" id="cms-content-21" class="cms-content"><div class="cms-edit-icon" style="opacity: 0.5;">Edit</div><div id="cms-content-21-overlay" class="cms-page-overlay"></div><div contenteditable="true" style="position: relative;" class="cke_editable cke_contents_ltr cke_show_borders">mini storage, indoor storage, boat storge, climate controlled storage, business storage, vehicle storage, household storage, document storage, moving storage, temporary storage</div></div>">
are you logged in to the CMS Admin? that looks like code for the live edit.
sandy170299
Yes, I was logged into the admin area. Good call! When I logged out, the garbage went away. However, that could be confusing to clients, if they happen to see that. Is there any way to prevent that from happening?
add an extra false parameter:
<title><?php echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'home', 'title',false); ?></title>
sandy170299
Sorry, that didn't work. it's all still showing up on the page.
