percent discount basd on quantity with hard coded add to button
Thread begun 12/18/2013 1:35 pm by steve204795 | Last modified 12/20/2013 7:37 am by Jason Byrnes | 6817 views | 16 replies |
steve204795
Hi .. I have added calculations and trigger as in support forum varying percentages based on quantity .. I'm not getting the discount showing on the confirm page. I've had to modify the checkout to get this to work with First Data's hosted checkout and it currently works but now my client wants to add 3 discount levels for quantity ranges 6-10 11-15 16-20 .. 3 files are attached ... thanks
on the fire exinguishers page, in the add to cart button, the discountPercentage column is set to gt it;s value from the cart:
$ATC_itemdiscountPercentage = "".$eCart1->DisplayInfo("discountPercentage") ."";// column binding
this is circular logic, it cant get the value from the cart, the add to cart is trying to add the value to the cart.
this should be set to the desired percentage instead, for example, 20%:
$ATC_itemdiscountPercentage = "0.2";// column binding
steve204795
Hi Jason .. thanks ... so just to clarify:
- I would need to create a column for each percentage range and then add a trigger
quantity more than 5 less than 11 > $ATC_itemdiscountPercentage1 = "0.1";// column binding
quantity more than 11 less than 16 > $ATC_itemdiscountPercentage2 = "0.2";// column binding
quantity more than 16 > $ATC_itemdiscountPercentage3 = "0.3";// column binding
I had changed the calculation in the original post to .... * [discountPercentage]:0.1... thinking that was where to input the percentage - I need to change that back to 0 correct?
Thanks again for your help
so you would have the discountPercentage1, discountPercentage2, and discountPercentage3 columns
in the add to cart button behavior, on the bindings panel. you would add the percentages 0.1, 0.2, 0.3 to the corresponding columns.
then you would change the calculation to assign the appropriate discount based on quantity:
(abs([Quantity] >= 5 && [Quantity] < 11)?[Price] * [Quantity]) * [discountPercentage1]:0) + (abs([Quantity] >= 11 && [Quantity] <= 16)?[Price] * [Quantity]) * [discountPercentage2]:0) + (abs([Quantity] >= 16)?[Price] * [Quantity]) * [discountPercentage1]:0)
steve204795
line 12 is getting an error in the eCart1PHP.php .. see attached .. thanks
steve204795
here's the full error ...
Parse error: syntax error, unexpected ')' in /home/content/a/f/p/afpdns/html/WA_eCart/eCart1_PHP.php on line 12
sorry, was missing some parentheses in the calculation code, the correct calculation code should be:
(abs([Quantity] >= 5 && [Quantity] < 11)?([Price] * [Quantity]) * ([discountPercentage1]:0)) + (abs([Quantity] >= 11 && [Quantity] <= 16)?([Price] * [Quantity]) * ([discountPercentage2]:0)) + (abs([Quantity] >= 16)?([Price] * [Quantity]) * ([discountPercentage1]:0))
steve204795
now it doesn't like one of the brackets '['
Parse error: syntax error, unexpected '[' in /home/content/a/f/p/afpdns/html/WA_eCart/eCart1_PHP.php on line 12
send the WA_eCart/eCart1_PHP.php file
steve204795
ok .. thanks - here it is
