client updating a table
Thread begun 12/18/2013 6:27 am by Jamie | Last modified 12/19/2013 12:50 am by Jamie | 1352 views | 2 replies |
Jamie
Hey Jason
Just looking for some advice/your opinion please.
Basically, one of my new sites *ideally* needs to allow the client to be able to upload a csv file to update a table in the database so that they can upload/update bulk entries rather than having to do them one by one.
What is your opinion on allowing a client to be able to do this - is it advisable or not? And how would one go about it using the WA tools?
Jamie
The WebAssist tools do not allow for updating the database using a CSV.
you would need to use phpMyAdmin to update the database in this way.
as for my opinion of allowing the client to do this, it would depend entirely on the client. I would need to take into account their knowledge of the database structure and abilities.
while it is convenient to update the database en mass using a CSV, it is also a bit tricky. it is quite easy to create a CSV file that will fail halfway through, and there is no way to undo the update other than revert to a backup.
I would train the client on backing up the database. I would also create a local copy of it to use for testing the import to work out any problems, have the client use the local copy of the database until they are sure the CSV is properly formatted before they import it to the live database.
Jamie
thanks for the advice Jason, really appreciate the input
