Free Shipping option for product category if it's the only one in the cart (flat rate cart)
Thread begun 12/16/2013 2:02 pm by sublucent | Last modified 12/17/2013 7:52 am by Jason Byrnes | 2995 views | 5 replies |
sublucentBeta Tester
I dug through the forums but couldn't piece together what I needed.
The cart that I've setup is flat rate shipping for the whole cart with a drop down to pick between store pickup (free), domestic, domestic express international, and international express, so no weights are used. Now we have added gift cards to the store. The gift cards are in their own category (from a relational table). I've bound the category ID to the WA eCart AddToCart. The gift cards will be emailed so they need to be free shipping if gift cards are the only products in the cart.
The current shipping rules use session variables set from the shipping option drop down menu in the cart. I created a new rule for the gift cards using the trigger condition "Number of items with a specific column value" where Category of 52 (the category ID for gift cards) is > 0. It seems that I now need to add another trigger that checks the cart for any items that are not from Category 52 so it will use the other shipping rules and not make the whole cart free shipping. I haven't been able to figure out how to do this.
Thanks for you time!
//eCart Rule
function WAEC_yoCart_USPS()  {
  $totalShipping = 0;
  if (true && (((isset($_SESSION['eCartCheckoutForm_shipping_country'])?$_SESSION['eCartCheckoutForm_shipping_country']:"") == "US") && ((isset($_SESSION['eCartCheckoutForm_shipping_method'])?$_SESSION['eCartCheckoutForm_shipping_method']:"") == "Standard"))) {
    $totalShipping += 6;//Result
  return WA_eCart_FormatNumber($totalShipping, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
//eCart Rule
function WAEC_yoCart_DomesticExpress()  {
  $totalShipping = 0;
  if (true && (((isset($_SESSION['eCartCheckoutForm_shipping_country'])?$_SESSION['eCartCheckoutForm_shipping_country']:"") == "US") && ((isset($_SESSION['eCartCheckoutForm_shipping_method'])?$_SESSION['eCartCheckoutForm_shipping_method']:"") == "Express"))) {
    $totalShipping += 50;//Result
//eCart Rule
//eCart Rule
function WAEC_yoCart_International()  {
  $totalShipping = 0;
  if (true && (((isset($_SESSION['eCartCheckoutForm_shipping_country'])?$_SESSION['eCartCheckoutForm_shipping_country']:"") != "US") && ((isset($_SESSION['eCartCheckoutForm_shipping_country'])?$_SESSION['eCartCheckoutForm_shipping_country']:"") != "") && ((isset($_SESSION['eCartCheckoutForm_shipping_method'])?$_SESSION['eCartCheckoutForm_shipping_method']:"") == "Standard"))) {
    $totalShipping += 18;//Result
//eCart Rule
//eCart Rule
function WAEC_yoCart_InternationalExpress()  {
  $totalShipping = 0;
  if (true && (((isset($_SESSION['eCartCheckoutForm_shipping_country'])?$_SESSION['eCartCheckoutForm_shipping_country']:"") != "US") && ((isset($_SESSION['eCartCheckoutForm_shipping_country'])?$_SESSION['eCartCheckoutForm_shipping_country']:"") != "") && ((isset($_SESSION['eCartCheckoutForm_shipping_method'])?$_SESSION['eCartCheckoutForm_shipping_method']:"") == "Express"))) {
//eCart Rule
//eCart Rule
function WAEC_yoCart_EmptyShipping()  {
  $totalShipping = 0;
  if (true && (((isset($_SESSION['eCartCheckoutForm_shipping_country'])?$_SESSION['eCartCheckoutForm_shipping_country']:"") == ""))) {
    $totalShipping += 0;//Result
//eCart Rule
//eCart Rule
function WAEC_yoCart_StorePickup()  {
  $totalShipping = 0;
  if (true && (((isset($_SESSION['eCartCheckoutForm_shipping_method'])?$_SESSION['eCartCheckoutForm_shipping_method']:"") == "Store Pickup"))) {
//eCart Rule
//eCart Rule
function WAEC_yoCart_GiftCertificate()  {
  $totalShipping = 0;
  if (true && (($this->ConditionalTotal("Quantity", "Category", "52") > 0))) {
//eCart Rule
createing a shipping rule with a 0 dollar value will not cancel the other rules out, the shipping rules are cumulattive.
to offer free shipping, you need to add a condition to the other rules so they will not apply.
on the calculations tab, add a new calculation as:
applyShipping:
abs([Category] == 52)?0:1
then in your shipping rules add an additional trigger:
AND
"Subtotal for any cart column"
if the subtotal for column "applyShipping" is ">" a value of "0"
Does this: abs([Category] == 52)?0:1 only trigger if only Category 52 is in the cart? So if category 52 and category 51 are in the cart will it return 1 for false and then the regular shipping will apply? Or does it just check if 52 is in the cart category array and return 0 for true?
Thanks for your help!
calculations are performed on a line item basis,
so if you have 3 items in the cart, the calculation will be preformed 3 times.
on the first line, if the Category is 52, the calculation will return 0, if not it will return 1
Same for the second line and the third line.
in your shipping rules the added trigger:
AND
will apply shipping if there is an item that is not in the 52 category in the cart.
That did it! Thank you so much for your quick responses. Life saver!
you're welcome.
