Insert into two tables with insert record server behavior
Thread begun 12/16/2013 8:20 am by Jedi | Last modified 12/16/2013 10:32 am by Jason Byrnes | 2371 views | 3 replies |
Jedi
I have a table with serveral fields that is currently inserts into a database table Workbook. I want to take the company name field in the form and also have that field be added to a table called Partner. How do i do this?
Use 2 insert record behaviors.
make sure the first one does not redirect to another page, only have the redirect on the last one.
Jedi
Thanks Jason. I will try that. Also, how do i check to see if that name already appears and if it does then not do the insert?
Example: if the new workbook already has a Partner Company 1 then not add Company 1 again.
that would take some hand coding.
you would need to create a recordset to lookup the entered company name, then add an if statement around the second insert behavior to only trigger if the recordset is empty.
