Search and joined table of the same kind error
Thread begun 12/14/2013 12:30 pm by Miguel | Last modified 12/16/2013 8:18 am by Jason Byrnes | 1062 views | 2 replies |
Miguel
Hello Community
Im making a new CMS and this time im allowing categories and pages to have parents of them self due to multilingual, i used datassist to create the insert update results etc..., i had to change the query because it was not working due to the join been the same table, for example the main language is English after inserting i have an extra button to insert the same page translated to Spanish, this will add a new page and it has a column for the parents id example of the query:
SELECT
abc_article_cat.*,
tabla2.id AS cat2,
tabla2.Name AS name2,
tabla2.Parent_id AS parentid2,
tabla2.Alias AS alias2,
tabla2.Thumbnail AS thumb2
FROM abc_article_cat
LEFT OUTER JOIN abc_article_cat tabla2
ON abc_article_cat.Parent_id = tabla2.id
The data displays correct until i try to use the search im getting this message it changes depending on the field but its basically the same msg: Column 'Lang' in where clause is ambiguous, is there any way around to get the search working when using a join on the same table, i also notice even that the original query has an alias for the names, inside the search wizard it doesn't show that just grabs the table twice?
Miguel
Never mind after several test it seems we have to add the alias of tables by hand example aliasname.columnname
//comparison list additions
  $WADbSearch1->addComparisonFromEdit("abc_article_cat.id","id","AND","=",1);
  $WADbSearch1->addComparisonFromEdit("abc_article_cat.Parent_id","Parent_id_Cat","AND","=",1);
  $WADbSearch1->addComparisonFromEdit("abc_article_cat.Name","Name","AND","Includes",0);
  $WADbSearch1->addComparisonFromEdit("abc_article_cat.Layout","Layout","AND","=",1);
  $WADbSearch1->addComparisonFromEdit("abc_article_cat.Active","Active","AND","=",1);
  $WADbSearch1->addComparisonFromEdit("abc_article_cat.Lang","Lang","AND","Includes",0);
Yes, data assist search will only recognize the column names from your table, not aliases you create in the SQL.
it is a good practice to avoid duplicate column names in your table to prevent this problem.
