Notice: Undefined variable: totalRows_WADAproperties
Thread begun 12/13/2013 4:51 pm by info145869 | Last modified 12/16/2013 8:36 am by Jason Byrnes | 2611 views | 3 replies |
info145869
used data assist , getting the following error
Notice: Undefined variable: totalRows_WADAproperties in D:\Domains\sirealestate.com\wwwroot\siteadmin\properties_results.php on line 23
using dw cs latest versions of everything. Windows 7
move the code for the recordset that is at lines 86 - 139:
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$maxRows_WADAproperties = 10;
$pageNum_WADAproperties = 0;
if (isset($_GET['pageNum_WADAproperties'])) {
$pageNum_WADAproperties = $_GET['pageNum_WADAproperties'];
$startRow_WADAproperties = $pageNum_WADAproperties * $maxRows_WADAproperties;
mysql_select_db($database_con_silbert, $con_silbert);
$query_WADAproperties = "SELECT id, prop_name, prop_county, prop_status, featured FROM properties ORDER BY prop_name DESC";
$query_limit_WADAproperties = sprintf("%s LIMIT %d, %d", $query_WADAproperties, $startRow_WADAproperties, $maxRows_WADAproperties);
$WADAproperties = mysql_query($query_limit_WADAproperties, $con_silbert) or die(mysql_error());
$row_WADAproperties = mysql_fetch_assoc($WADAproperties);
if (isset($_GET['totalRows_WADAproperties'])) {
$totalRows_WADAproperties = $_GET['totalRows_WADAproperties'];
} else {
$all_WADAproperties = mysql_query($query_WADAproperties, $con_silbert);
$totalRows_WADAproperties = mysql_num_rows($all_WADAproperties);
$totalPages_WADAproperties = ceil($totalRows_WADAproperties/$maxRows_WADAproperties)-1;
to line 4.
info145869
K thanks
There was another user who had a similar issue that was caused by the DW Installation. he corrected the problem by recreating the users configuration folder and re installing:
http://www.webassist.com/forums/posts.php?id=33047
