DataAssist Insert Error
Thread begun 8/18/2009 2:15 pm by Les Crowley | Last modified 8/18/2009 3:14 pm by Les Crowley | 1789 views | 2 replies |
Les CrowleyBeta Tester
This just started and is happening on existing DA Inserts as well as when I try to implement a new instance of DA Insert.
I have uninstalled and reinstalled DA as well as deleted the DW cache file from the config folder.
Dreamweaver
While executing onLoad in WAAB_Insert_SB.htm, the following JavaScript error(s) occurred:
In file "WAAB_Insert_SB":
initializeUI is not defined
OK
This really sounds like the winfilecache issue. Are you sure you had DW closed when you deleted the winfilecache? Try again and make sure DW is closed when you delete the cache file. This is the exact error that is usually as a result of that problem.
Yep that's what it was. On older versions of Dreamweaver I would delete the win cache file with DW open because once in a while it wouldn't start up if I deleted it with it closed. Closing it and deleting the cache file did the trick.
Thanks Ray!!
