Products Detail page Gallery hovering
Thread begun 12/13/2013 10:34 am by Roz431315 | Last modified 12/30/2013 12:13 pm by Jason Byrnes | 6755 views | 11 replies |
Roz431315
Hi Jason,
Question 1:
I would like to comment out the code that shows the gallery image (Title and Description and the box that surrounds it) when you hover over the image in the products detail page only. I have a new arrivals gallery on the home page that seems to use the same (div class="pg-rlp-tip)
URL - http://www.relicvintage.com/products_detail.php?ProductID=26
Question 2:
What is the suggested way to insert a facebook (Like, share) button into the site. On the facebook site you can download plugin code and have the option of (HTML5, XFBML, IFRAME, URL) Do I insert this code? and do I need to login to facebook using my customers login information?
in the galleries/tiny_ribbon_lightbox/js/gallery.js file, remove the tooltip code:
//tooltips
this.tips = new Tips(this.thumbs.images, {
className: 'pg-rlp-tip',
offset: {'x': -100, 'y': -105},
showDelay: 1,
hideDelay: 1,
onShow: function(tip) {
this.options.offset.y = this.tip.getSize().y * -1 - 15;
this.tip.setStyle('top', (pgMousePosition.y + this.options.offset.y) + 'px');
this.tip.fade('show');
onHide: function(tip) {
this.tip.fade('hide');
this.tip.setStyle('top', '0px');
yes, you can add the face book code to your pages, you dont have to log into face book with your clients account.
Roz431315
FaceBook
Thanks Jason, that worked for the hover,
With FaceBook, I pasted the code from FaceBook and I get an error, I'm probably misunderstanding something.
http://www.relicvintage.com/index.php
this is the code I pasted into index.dwt.php:
<div id="fb-root"></div>
<script>(function(d, s, id) {
var js, fjs = d.getElementsByTagName(s)[0];
if (d.getElementById(id)) return;
js = d.createElement(s); js.id = id;
js.src = "//connect.facebook.net/en_US/all.js#xfbml=1&appId=283841131730716";
fjs.parentNode.insertBefore(js, fjs);
}(document, 'script', 'facebook-jssdk'));</script>
<div class="fb-like" data-href="https://developers.facebook.com/docs/plugins/" data-layout="standard" data-action="like" data-show-faces="true" data-share="true"></div>
what is the error?
Roz431315
My bad I the removed the code...I put the HTML5 code back, the error is a red color text that says " Error"
should I be using other types of code (XFBML, IFRAME, URL) from facebook?
When I signed into FACEBOOK to get the code with my ID it looks like it sets it up for me ( my facebook page), I believe I have to signed in with the ID and pass with the person who I built the website for, correct?
I have now tested it in Safari, IE and Chrome, no error but no facebook icon, there is an error in Firefox as noted above.
I don't think I am suppose to you HTML5 code?
I'll be 100% honest, I'm not familiar with the code that face bool generates.
we offer a social media toolkit plugin that is included with Design Extender for adding Like Buttons, that generates the code for you. you could try using the XML version instead of the HTML 5 version, but i rely cant give much advice about it, as I'm not to familiar with it.
Roz431315
Ok a couple of things, FaceBook is rolling out new buttons, see attached, I have the latest social media toolkit, I think it needs to be updated.
When I do figure this out are the proper PHP pages...index.dwt.php and page.dwt.php? or
adding the like button to
index.dwt.php
will show it on the home page
adding it to:
page.dwt.php
will show the like button on all other pages.
Roz431315
Hi Jason,
When scrolling through a gallery, there is a Title and Description that is displayed, above the (image 1 of 4). What code needs to be commented out to not display the Title and Description by default. This would allow the customer not have to blank out the Title and Description when adding Galleries.
http://www.relicvintage.com/products_detail.php?ProductID=27
Would it be in in the galleries/tiny_ribbon_lightbox/index.php lines 61 -62?
see my original reply:
http://www.webassist.com/forums/post/163729/
