Problem inserting table rows in IE (HTML table)
Thread begun 12/13/2013 5:58 am by Willi Schneider | Last modified 12/13/2013 8:06 am by Jason Byrnes | 4386 views | 3 replies |
Willi Schneider
Hi all
My client has a problem to insert a row into an HTML table with CKEditor and Internet Explorer.
Right click inside table cell and add table row above/below does not work anymore.
I am able to reproduce this.
When trying to insert a new row, as described above, the context menu in CKE opens, but the cursor jumps to the top of the editor field, instead.
System info:
Win 7 Pro
DataBridge 1.1.4 with CKEditor 4.0 (revision 769d96134b)
Internet Explorer (client version probably IE8, could not tell. My version is IE11)
Additional info: When adding the site to be viewed compatibility mode in IE11, the row insertion works.
Firefox, Chrome and Opera work.
Any bugfix?
Thanks in advance
Willi
CKEdiitor 4.0 is not compatible with IE 11
you can update the CKEditor Files manually.
in the webassist/ folder, rename the ckeditor folder to ckeditor_bak
On this page:
download
click the button to launch CK Builder. Select to use the Full Preset, and the Kama Skin.
Copy the downloaded CKEditor folder to the webassist folder in your site.
from the ckeditor_back folder, copy the following three files:
ckeditor.php
ckeditor-php4.php
ckeditor-php5.php
and paste them in the new ckeditor folder.
you will need to clear the browsers cache to see the updates take effect.
Willi Schneider
Thank you very much
Hey Jason
As always, excellent support.
It works!
Thanks from Munich
Willi
you're welcome.
