contact form problem
Thread begun 12/13/2013 3:34 am by eladgraphics386618 | Last modified 12/05/2017 1:48 pm by Ray Borduin | 4128 views | 7 replies |
eladgraphics386618
Hello
when launching contact form on dreamweaver 6 I am having this issue.
thanks so much
My number is 770-453-9200
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
eladgraphics386618
Hello
Thanks so much for your reply. I have another problem. I have clear my computer and reinstall dreamweaver cs6 and data bridge new.
when I build a form I get the thank you page but no email.
thanks
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
eladgraphics386618
problem with contact form cc 2017
I have been away for some time and do not remember how to submit a new post. very sorry.
I have installed cc 2017 and my current work form does not expend. I have attached the screen shot and a text file.
thanks so much
Please install the latest version of Data Bridge. There was an issue with the bindings panel that we have corrected.
eladgraphics386618
Hello Ray
I have installed the update and I got a difference kind of screen but the same problem.
1. the contact page did not start with "<?php require_once("webassist/ckeditor/ckeditor.php"); ?>"
I've copied it from another site and paste it here.
2. I still did not get the form to open.
I am attaching the contact and thank page and a screen shop after I have installed the update.
thanks for you time
I was able to find and fix this issue. Please reinstall Data Bridge and the bindings should work from within form builder properly. You will probably have to click the refresh button in bindings after opening it.
