eCart Checkout page not loading to Confirm page
Thread begun 12/12/2013 10:05 am by phill401410 | Last modified 12/13/2013 11:07 am by Jason Byrnes | 4348 views | 7 replies |
phill401410
I get this error on the confirm.php page after filling out checkout.php
Fatal error: Call to a member function IsEmpty() on a non-object in /data/20/1/125/115/1940604/user/2116827/htdocs/ItsNotHardTo/confirm.php on line 224
Went through several forums but could not find anything my level of expertise could grasp.
Files attached
the confirm page is missing the following code at line 1:
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
$eCart1->GetContent();
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
actually, the checkout wizard should have added other code to the confirm page as well, for processing the order through the gateway.
I would delete the checkout pages and re run the checkout wizard.
phill401410
Jason
That solved that little issue. Hope I didn't accidentally delete the code. Everything works fine, went right to PayPal. Glorious.
So I will delete all pages after cart: checkout, checkout_success, checkout_failure, confirm and rerun checkout wizard to see what else gets added to confirm code.
_____________________________________________
When you check the box for Shipping Info Same as Billing Info on checkout.php, the Order Confirmation page, confirm.php, does not pick that up. Then PayPal kicks you out if you do not go back and enter Shipping Info.
Good news, the Remote Server Table, Order Detail, received data !!!!!!!!!
Files attached
send a link please
phill401410
sent link in PM
On the checkout page, there should be the following code just before the </head> tag:
<script src="WA_eCart/Scripts/copyShipping.js" type="text/javascript"></script>
phill401410
Worked perfectly, never any doubt! Thanks and happy Friday 13th
you're welcome.
