Is there any way to change thumbnail type from 'text' to 'display as image'. I can't rebuild the whole thing after spending time & money getting it set up to work with PayPal Advanced!
Thread begun 12/12/2013 9:58 am by CGil09875565 | Last modified 12/12/2013 1:12 pm by Jason Byrnes | 3846 views | 6 replies |
CGil09875565
eCart 5.07 on Win8-64bit system
I thought it was set up correctly but I guess I missed this one extremely annoying step - don't judge, my first ever attempt at a shopping cart. I had also initially deleted 'weight column (not needed) but it came back and no option to delete it now.
If it's not possible, I'll just have to live with it.
I dont follow, please provide more details.
both of these can be accomplished by editing the the cart display code by hand
In design View, right click on the weight column header, and select Table -> Delete Column
for the thumbnail, select the thumbnail text and co to code view. the code will look similar to:
<?php echo $eCart5->DisplayInfo("Thumbnail"); ?>
add an image tag around that
<img src="<?php echo $eCart5->DisplayInfo("Thumbnail"); ?>" />
you may want to add a hight or width as well.
CGil09875565
New images attached
Viewing code on cart page - added attachments so you can see what I have.
you may have to add the path to the thumbnails folder:
<img src="images/path/<?php echo $eCart5->DisplayInfo("Thumbnail"); ?>" />
CGil09875565
Finally got the thumbnail to show! You and Ray now officially share the "most awesome tech support ever" award. Thank you!!
Glad to hear it is working.
