Reduce Qauntity
Thread begun 12/12/2013 2:57 am by Paolo R | Last modified 12/19/2013 8:49 am by Jason Byrnes | 2896 views | 5 replies |
Paolo R
Reduce Qauntity
Hi Jason,
I've got my store setup and until now stock management wasn't needed.
The entire process is setup and working great.
I have just added the 'Quantity' column to my database table, but it's obviously not reducing by the ordered quantity when a order is put through.
How do I go about setting things up now?
Thanks,
Paolo
you would need to write a loop through the cart items, with an update statement to lookup the item ID and update the Stock Column
$eCart1->MoveFirst();
while (!$eCart1->EOF()) {
<lookup the item ID using $eCart1->DisplayInfo("ID") to return the available qty>
<update the AvailableQuantity - Quantity Ordered>
$eCart1->MoveNext();
The exact specifics for implementing this depend on the gate way being used, if you need help with this, we can help in a premiere support appointment:
http://www.webassist.com/premier_request.php
Paolo R
see PM
see PM
Paolo R
See PM
see PM
