checkout wizard in e-Cart
Thread begun 12/11/2013 8:43 am by av3103798 | Last modified 12/11/2013 9:00 am by av3103798 | 2079 views | 4 replies |
av3103798
hi, my payment gateway is based on Authorize.net How do I choose this during the checkout wizard?
thanks
eCart only supports authorize.net.
if you want to use an unsupported gateway, you will need to hand code the checkout process.
we can help you with this in a premiere support appointment:
http://www.webassist.com/premier_request.php
av3103798
authorize.net
Yes, it is the same as authorize.net. But in the wizard, I only see two choices: Paypal Standard, and Paypal pro, and links to sign up for others.
On the first screen of the Checkout wizard, set the selection to Accept Credit Cards.
your screen shot is what you see if you use the Accept Credit cards and Paypal option.
if you use the Accept Credit Cards option, you will be able to choose from a wider list of gateways.
av3103798
Thanks!
That's what I was looking for. I really appreciate your lightning fast support.
Angelo
