Edit DataBridge Preset....
Thread begun 12/09/2013 8:26 pm by akstudio | Last modified 12/11/2013 7:12 am by Jason Byrnes | 4257 views | 7 replies |
akstudio
So, I followed the Display nested recordsets tutorial. It is (almost) exactly what I need. I need to change the menu item names in the table to something else more in-tune with my project, I also need to add in about 8 more rows to the "menu_items" database.
How can I edit the preset that comes with that tutorial, so that I can have the preset manager create the DB and its relationship with all my additional row information?
I tried to just update the names of the rows in phpmyadmin, but quickly realized I am heading for a logistical headache. I looked at the xml, and no one in their right mind would attempt to edit this without full understanding of its structure.
First, edit the tables to use the structure you need
Then you need to recreate the presets so that they use your tables structure, select the new from blank preset, then select your table.
on the manage pages tab, go onto the fields and settings section to set the labels, element types, and validation.
then set the pages to be created, and which fields to create.
When done save your new preset.
you can reuse that preset to have it create the tables on a new project.
akstudio
Thanks.
Just so I get this right, do I need to set up the table row relationships first in phpmyadmin (Actually, im using the old school gui tools)? Then, set them up in the preset manager? or can I choose which columns to associate within the preset manager and allow the tool to build the relationship?
You need to set up the tables in the database first. you don't need to specially define columns as being Foreign keys in the database, but the columns need to exist before they can be used in the data assist wizard.
akstudio
OK, that helped. I muscled through it, made a few mistakes, and learned along the way. This is now set up, thanks.
One more question, and this might be a bit complex. How can I take that tutorial (Display nested recordsets) and apply the "master/detail" functionality to it?
I've tried a lot of things to get it to work, but no luck.
The closest I came was inserting the master/detail functionality first. Then, I went back and followed the steps in the tutorial. If I edit the filter, as in the tutorial, on the items recordset, I get no data, but the recordset loops the right amount of categories.
If I leave the filter set to none, I only get one record, and no loops of the item data.
I feel I am close, but I just need a bit of help.
I dont follow, the master detail concept is to have a master list showing all product for example, then a link that passes the product ID to a details page to show only the one product.
From your description, it sounds like you are trying to show the detail on the master page, that wont work.
akstudio
I understand the concept of master/detail. However, I also want to loop through categories.
What I have is this:
8 Categories
96 Items (ItemTitle, Item Description, ItemStatus, ItemID, ItemDate, ItemIssues, etc)
On my "master page" I need to list out each category, and under each category, I need to display ItemTitle, ItemDescription (truncated) and ItemID. Clicking the ItemName would go to it's detail page, displaying the Category it's associated with, along with all of the items information.
I need the ability to add/edit and insert future categories, and categorize items to these categories. When I began building the page, I thought of using master/detail initially, but when I started to think about it, I needed to loop through categories and display them, then loop through items and display them under the proper category. Then I found the tutorial on nested recordsets.
Maybe I am going about this all wrong?
ok, so within the listing for the items, create a link to the details page that passes the ItemID as a URL parameter
details.php?ItemID=4
on the details page, crate a recordset that uses the ItemID URL parameter to filter the correct product.
