quick data assist question
Thread begun 12/09/2013 3:04 pm by Ericspecullaas | Last modified 12/10/2013 1:04 pm by Ericspecullaas | 3431 views | 6 replies |
Ericspecullaas
i noticed that in data assist that you can upload images quickly and effortlessly. I have noticed that it has a hard time putting said images or files into numbered folders when I use this script
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../projects/".$row_Recordset1['id'] ."",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
?><?php
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End
?><?php
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Insert"]) || isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "image1-1", "0", "", "false", $WA_UploadResult1_Params);
?><?php
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
WA_DFP_UploadFiles("WA_UploadResult2", "image1-1_thumb", "0", "", "false", $WA_UploadResult2_Params);
it sends the files to the folder named projects. But when I use this script
'UploadFolder' => "../projects/test",
?><?php
?><?php
?><?php
it makes the folder in the folder but I dont need all my files in 1 folder I need them in different numbered folders.
thanks,
Eric
How is the recordset defined?
Is the recordset code before the upload code?
it would be more helpful to attach the entire page so i could see the code in contest.
Ericspecullaas
<?php require_once("../webassist/file_manipulation/helperphp.php"); ?>
?><?php
?><?php
?><?php
?><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<script src="../webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<link href="../webassist/forms/fd_basic_default.css" rel="stylesheet" type="text/css">
<link href="../webassist/forms/dataassist_button.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div id="Insert_Basic_Default_ProgressWrapper">
<form enctype="multipart/form-data" class="Basic_Default" id="Insert_Basic_Default" name="Insert_Basic_Default" method="post" action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
<fieldset class="Basic_Default" id="Insert">
<legend class="groupHeader">Insert</legend>
<div class="lineGroup"> <label for="image1-1" class="sublabel" > image1-1:</label>
<div class="errorGroup">
<span>
<input name="image1-1" type="file" id="image1-1" size="30" tabindex="1">
</span>
</div>
</div>
<div class="lineGroup"> <label for="image1-1_thumb" class="sublabel" > image1-1_thumb:</label>
<span>
<input name="image1-1_thumb" type="file" id="image1-1_thumb" size="30" tabindex="2">
</span>
</div>
</div>
<span class="buttonFieldGroup" >
<input id="id" name="id" type="hidden" value="<?php echo((isset($_GET["invalid"])?ValidatedField("testinsert","id"):"")); ?>">
<input type="submit" value="Insert" class="formButton" id="Insert" name="Insert" />
</span>
</fieldset>
</form></div><div id="Insert_Basic_Default_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('Insert_Basic_Default', 'Insert_Basic_Default_ProgressMessageWrapper', WADFP_Theme_Options['BigSpin:Slate']);
</script>
<div id="Insert_Basic_Default_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="../webassist/progress_bar/images/slate-largespin.gif" alt="" title="" style="vertical-align:middle;" />&nbsp;&nbsp;Please wait</p>
</div>
</div>
</body>
</html>
there is no recorcdset on this page.
in the download code you are using a referance to a recordset value:
but there is not a recordset named Recordset1, or any other recordset defined on the page.
Ericspecullaas
add the offending recordset
i have added the missing recordset but now all its giving me is the first id(1) or name(test name) here is the code as I currently have it.
<?php require_once('../Connections/acme.php'); ?>
<?php require_once("../webassist/database_management/wa_appbuilder_php.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_acme, $acme);
$query_Recordset1 = "SELECT * FROM project";
$Recordset1 = mysql_query($query_Recordset1, $acme) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
'UploadFolder' => "../projects/".$row_Recordset1['fieldset_Project_Name_Text'] ."",
// WA DataAssist Insert
if (isset($_POST["Insert"]) || isset($_POST["Insert_x"])) // Trigger
$WA_connection = $acme;
$WA_table = "project";
$WA_sessionName = "WADA_Insert_project";
$WA_redirectURL = "test_insert.php?id=[Insert_ID]";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "id|image1-1|image1-1_thumb";
$WA_fieldValuesStr = "".((isset($_POST["id"]))?$_POST["id"]:"") ."" . $WA_AB_Split . "".($WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]) ."" . $WA_AB_Split . "".($WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"]) ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_connectionDB = $database_acme;
@session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
if ($WA_redirectURL != "") {
$WA_redirectURL = str_replace("[Insert_ID]",$_SESSION[$WA_sessionName],$WA_redirectURL);
<html>
<head>
</head>
<body>
<span>
</span>
</div>
</div>
<span>
</span>
</div>
</div>
</span>
</fieldset>
</script>
</div>
</div>
</body>
</html>
mysql_free_result($Recordset1);
im wondering how to make it so that I have the new id (1045) not id of 1 every time. I have tried a session id but it didn't work.
thanks for you pointers
you don't have the recordset filtered by anything
how do you plan to determine which record should be returned?
I need more details on how the application is configured.
Ericspecullaas
i figured it out. i took this
'UploadFolder' => "../projects/",
and added
'UploadFolder' => "../projects/".$_POST['folder_name'] ."",
it now adds a new folder and add's it to the db as well
thanks for your help
from Eric
