Is there a limit to how my records can be displayed?
Thread begun 12/05/2013 8:19 am by vernon webb | Last modified 1/22/2016 10:49 am by Ray Borduin | 9979 views | 41 replies |
vernon webb
I set up a map (http://www.rsavvy.com/io/map.php) and the map has 78 records however only about 20 or so are actually being displayed. Is there a limit to how many can be displayed at once?
vernon webb
vernon webb
oopps
see PM
vernon webb
Why is it required :O
I visited your page today, And it looks like you found the problem? i see quite a lot more points showing on the map today.
vernon webb
No, I have not resolved the issue. As far as I can tell there are only about 25 there but should be 78.
in fire bug i see many 500 server error messaages on trying to post to the file:
http://www.rsavvy.com/io/google_javascript/promaps_geocache_php.php
that file is used to generate a cache of addresses so the map does not have to post to the google geocoder every time the page loads.
It is probably a permissions error. using File Zilla or another FTP program, change the permissions on the google_javascript/ folder and all files under it to 755
vernon webb
Didn't help
