validation
Thread begun 12/05/2013 7:22 am by CraigR | Last modified 12/09/2013 2:00 pm by Jason Byrnes | 5757 views | 11 replies |
CraigRBeta Tester
validation
I have a form with a very simple check, where a user enters their email address for validation, (no password).
If the address is on the database, the user is redirected to another page, where their memberid should be appended as a get parameter.
When I set up the form with the user authentication wizard, I set emailaddress as the only column to be validated.
Can I get the memberid from my table at the same time the user authentication behaviour checks the emailaddress, (without the need to compare it), or do I need to add a lookup query to the page using the post email address as a parameter ?
if(isset($_POST["Check"]) || isset($_POST["Check_x"])){
$WA_Auth_Parameter = array(
"connection" => $PowerCMSConnection,
"database" => $database_PowerCMSConnection,
"tableName" => "tblmemberscontact",
"columns" => explode($WA_Auth_Separator,"MemberEmailAddress"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["emailaddress"]))?$_POST["emailaddress"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text"),
"sessionColumns" => explode($WA_Auth_Separator,"MemberContactID".$WA_Auth_Separator."MemberID"),
"sessionNames" => explode($WA_Auth_Separator,"MemberContactID".$WA_Auth_Separator."MemberID"),
"successRedirect" => "../events/booktickets.php?EventID=".$_GET['EventID']."&MemberID=".$_SESSION['MemberID'],
"failRedirect" => "../events/booktickets_check.php?failed=true",
"gotoPreviousURL" => FALSE,
"keepQueryString" => FALSE
WA_AuthenticateUser($WA_Auth_Parameter);
I tried adding MemberID as a session variable, but the redirect seems to append the session value of the previous memberid to the url. I don't really need the session, i just wanted to use the memberid of the validated email address
the authentiocate user behaivor is set to store the member ID as a session variable:
but think about order of operations. this code block is setting a list of perameters that are going to be sent into the WA_AuthenticateUser function
you cant at the same time tell the function to lookup the session variable, and tell it to use the session in the success redirect:
the session hasn't been looked up yet.
leave the success redirect blank, and add header function after the WA_AuthenticateUser function
<?php header("Location: ../events/booktickets.php?EventID=".$_GET['EventID']."&MemberID=".$_SESSION['MemberID']); ?>
CraigRBeta Tester
I get what you are saying.
I tried as you suggested,, but now the authentication fails
at what point do i add the redirect ?
immediately after the WA_AuthenticateUser function, after the last curly bracket or in a separate block ?
do i need a block of code to confirm the user has been authenticated brfore the redirect is carried out ?
the header should be in a seperarte code block after WA_AuthenticateUser function
CraigRBeta Tester
Thanks Jason
I put the header in a
block,
using the logic that a fail redirect will reload the page before this line is reached.
seems to work ;-)
glad to hear it is working.
CraigRBeta Tester
oops, spoke too soon.
Bizarrely, it seemed to work at first, but now, it doesn't.
I know the email address I key in is correct, and if i put the redirect path after "successRedirect", it works.
If I change it to the code below, I get the failed message
"successRedirect" => "",
"failRedirect" => "/events/booktickets_check.php?EventID=".$_GET['EventID']."&failed=true",
header("Location: /events/booktickets.php?EventID=".$_GET['EventID']."&MemberID=".$_SESSION['MemberID']);
CraigRBeta Tester
PM
see PM
