Products Page not loading Cart Page
Thread begun 12/04/2013 6:53 am by phill401410 | Last modified 12/11/2013 12:15 pm by Jason Byrnes | 9066 views | 17 replies |
phill401410
Jason,
I am setting up an Ecomm site. The first page I made was a Product page using your tutorial, http://www.webassist.com/tutorials/Getting-started-with-MySQL-and-dynamic-websites. The second page I made was a cart page using http://www.webassist.com/tutorials/Add-a-shopping-cart-eCommerce-Series.
I created an Add to Cart Button and when I test products.php I get the error message; Notice: Undefined variable: ATC_itemQuantity in C:\xampp\htdocs\ItsNotHardTo\products.php on line 100. COuldn't find a solution in the forums. Thanking you for your help.
Files attached.
the where clauase of your recordset is not valid:
WHERE ProductName > '$50.00'
the product name is a text column, you cannot perform math function on text.
Greater than is a math function, one text value cannot be Greater than another text value.
the greater than comparison can only be performed on numbers.
This means your recordset is empty which is causing the add to cart function to fail, since there are no items in the recordset to lookup.
phill401410
Jason
Thank you for your prompt reply
I deleted WHERE ProductName > '$50.00' from the recordset
get this error
Notice: Undefined variable: ATC_itemQuantity in C:\xampp\htdocs\ItsNotHardTo\products.php on line 75
So in eCart Add from Recordset for Quantity I deleted the dynamic vale and set it to default 1
Still getting error
Thanking you in advance again.
Files attached.
_______________________________________________________________________
04DEC13 8:30 pm
Tried eliminating Quantity in Bindings Recordset (rsProducts), Server Behaviors Recordset (rsProducts)
Still throwing Notice: Undefined variable: ATC_itemQuantity in C:\xampp\htdocs\ItsNotHardTo\products.php on line 77
Files attached Ecomm-04DEC13-3.zip
the add to cart form is out side of the repeat region, it comes after the while loop:
<?php } while ($row_rsProducts = mysql_fetch_assoc($rsProducts)); ?>
<form name="eCart1_1_ATC_<?php echo $row_rsProducts["ProductID"]; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="eCart1_1_ID_Add" value="<?php echo $row_rsProducts["ProductID"]; ?>" >
<input type="image" src="WA_eCart/Images/Yosemite/Btn4_EN_addtocart.gif" border="0" class="eC_ImageButton" value="Add to Cart" name="eCart1_1_ATC">
</form>
it should be in one of the table cells inside the repeat region.
phill401410
thank you for your response. Got me redirected and I now have the Products Page playing nice with an Items Page per your tut http://www.webassist.com/tutorials/Getting-started-with-MySQL-and-dynamic-websites
Moving forward to getting my head around how to set up a an eCart shopping cart. Kate Forbes tutorials using eCart rewrite DW templates so am a little bit stymied there. More learning curves ahead.
Glad to hear it is working.
If you have further questions, don't hesitate to post them here.
phill401410
Take you up on that offer.
I can test index.html on the local server and it connects to product.php but throws error Warning: strpos() [function.strpos]: Empty delimiter in C:\xampp\htdocs\ItsNotHardTo\Connections\ItsNotHardTo_Copy_Copy.php on line 15
On the remote server index.html does not connect to product.php, Get Fatal error: No such file or directory in /data/20/1/125/115/1940604/user/2116827/htdocs/ItsNotHardTo/Connections/ItsNotHardTo_Copy_Copy.php on line 25
Could not find anything in Forum on strpos() [function.strpos]: Empty delimiter.
Suspect I have not found right combination in my Dynamic MySQL Connection - ItsNotHardTo_Copy_Copy.php
Files attached. Thanx again.
12:02pm
Did not have domain assigned to additional connection in ItsNotHardTo_Copy_Copy.php. Remote server now working.
in a private message, send a copy of the Connections\ItsNotHardTo_Copy_Copy.php file.
the error on the server:
means that the file:
has not been uploaded.
phill401410
Oops, Did not see your reply, I updated #7 with:
12:02pm
"Did not have domain assigned to additional connection in ItsNotHardTo_Copy_Copy.php. Remote server now working."
Thank you.
12:28
I entered data into all the empty columns in the database and it seems to have stopped throwing the errors. See "On the remote server index.html does not connect to product.php, Get Fatal error: No such file or directory in /data/20/1/125/115/1940604/user/2116827/htdocs/ItsNotHardTo/Connections/ItsNotHardTo_Copy_Copy.php on line 25" in #7.
Even a blind squirrel finds a nut once in awhile.
Copied the wrong error, should be "Warning: strpos() [function.strpos]: Empty delimiter in C:\xampp\htdocs\ItsNotHardTo\Connections\ItsNotHardTo_Copy_Copy.php on line 15"
So is this all set then? a little confused by the updates.
