Redirect after log in
Thread begun 12/03/2013 2:32 pm by jo271221 | Last modified 12/04/2013 10:48 am by Jason Byrnes | 6912 views | 3 replies |
jo271221
I want my user to be directed to an view/update page after successful log in. Currently I altered the success message with a link for clients and a link for assistants. I need to know how to append the url with ?UserID= - I don't know how to dynamically get or populate the user id here.
I tried this: <?php echo(isset($_GET['UserID'])?$_GET['UserID']:""); ?> and i also clicked on the parameter but did not see what I should use there.
when the user logs in, your login page is storing the User ID in a session variable named:
SecurityAssist_UserID
dont pass that value in the URL though, use the session on the redirect page instead of using the URL variable.
so on the confirm agree page, you have the recordset filtering the UserID on the URL variable, instead set the recordset to filter using the SecurityAssist_UserID session variable.
jo271221
Thank You!
Thank You! Here is the statement that I used and it is working.
mysql_select_db($database_PowerCMSConnection, $PowerCMSConnection);
$query_WADApcms2_users = "SELECT * FROM pcms2_users WHERE UserID = '".$_SESSION['SecurityAssist_UserID']."'";
$WADApcms2_users = mysql_query($query_WADApcms2_users, $PowerCMSConnection) or die(mysql_error());
$row_WADApcms2_users = mysql_fetch_assoc($WADApcms2_users);
$totalRows_WADApcms2_users = mysql_num_rows($WADApcms2_users);
yes, thats correct
