How to use php webassist and bootstrap together in design
Thread begun 12/02/2013 8:43 am by henrik441511 | Last modified 12/03/2013 2:40 pm by henrik441511 | 3398 views | 6 replies |
henrik441511
its just about cms, and its working fine, but when used together with bootstrap i have to use "" marks around the select statement to have responsive design to work. But when doing so and using cms when push the edit in browser for cms i also see the php code, is there a workaround?
example code:
mysql_select_db($database_PowerCMSConnection, $PowerCMSConnection);
$query_BlogRS = "SELECT C2.ContentGroup, C2.ContentPageSetOrder FROM pcms2_contents AS C1 LEFT OUTER JOIN pcms2_contents AS C2 ON C2.ContentPagesetParentID = C1.ContentID WHERE C1.ContentGroup = 'blogposter' ........."
Kind regards and thanks in advance
henrik441511
Sent on private..
see PM
henrik441511
private
I am not able to reproduce.
Try clearing the browsers cache. I have tested In Windows and Mac, and the edits are working, see screen shot.
henrik441511
private
