Multiple record insert, insert if not zero
Thread begun 12/02/2013 5:13 am by CraigR | Last modified 12/03/2013 7:52 am by Jason Byrnes | 2469 views | 3 replies |
CraigRBeta Tester
I love this server behavior, it speeds up development a lot.
I am using it to record ticket sales, where the user inputs the number of tickets they require for various options.
I have set the behavior so it only inserts a row if the ticket quantity is not blank, however, I would also like the option to skip insert if field value is zero.
Is there an easy way to do this without having to edit the 'WA_AB_checkLoopedFieldsNotBlank' function in wa_appbuilder_php.php ?
It seems fairly straightforward to change the function, but I wanted to keep this extra functionality for next time.
you could add some server code to change the value to be blank if it equals 0 at line 1 of your page:
<?php if(isset($_POST['Quantity']) && $_POST['Quantity'] == "0") $_POST['Quantity'] = ""; ?>
CraigRBeta Tester
That'll do it, thanks Jason.
I already created a new function this time, next time I won't need to
no worries.
