files not uploading
Thread begun 12/02/2013 3:03 am by Jamie | Last modified 12/02/2013 9:04 am by Jason Byrnes | 2072 views | 5 replies |
Jamie
files not uploading
Hey Jason
Struggling to work out why the 2 attached files dont upload either the CompanyLogo or the MemberPic files but the filenames are being updated within the db
Thanks and hope you had a great Thanksgiving...
Jamie
to troubleshoot, edit the update and insert server behaviors so that they do not redirect.
then open the bindings panel, expand the WA Uploaded Files Global Status binding group and add the Debug info binding to your page
next turn on error reporting by adding the following code at line 1:
error_reporting(E_ALL);
and dump the files contents by adding the following code at the end of the page before the closing <body> tag:
<?php var_dump($_FILES); ?>
test the upload again and post the results of the debug info and files collection.
Jamie
Hi Jason
On the update page the
array(2) { ["CompanyLogo"]=> array(5) { ["name"]=> string(14) "motley-001.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(14) "/tmp/phpSBZcos" ["error"]=> int(0) ["size"]=> int(114817) } ["MemberPic"]=> array(5) { ["name"]=> string(14) "motley-007.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(14) "/tmp/phpliVOnM
have attached the data from the debug is attached in 'update.text'
On the insert page
array(2) { ["CompanyLogo"]=> array(5) { ["name"]=> string(14) "motley-002.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(14) "/tmp/phpz6PBPU" ["error"]=> int(0) ["size"]=> int(173130) } ["MemberPic"]=> array(5) { ["name"]=> string(14) "motley-008.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(14) "/tmp/php8dnTkk"
and have attached the debug info in insert.txt
Cheers
Jamie
the debug info both shows a status code of 1:
statusCode : 1
meaning the files are being uploaded, the debug info says the upload is working fine.
Jamie
Ok thanks Jason. Will probably start from scratch with the 2 pages.
theres no need to start form scratch, they are working as intended.
