WA_AuthTK_Auth_User - JavaScript Error
Thread begun 11/29/2013 4:18 am by johna1964 | Last modified 11/29/2013 8:08 am by johna1964 | 1331 views | 2 replies |
johna1964
I am trying to secure a star rating widget so people browsing can see it, but they can't rate it until they have registered and logged in. I am receiving the following the error as shown in the attachment; however, I may not be doing it correctly.
What I am doing is selecting the ratings code; Security Assist > Authenticate User >(General Tab) Trigger: Rule: Logged into User > Pass original query string on redirect; (Database Tab) Table: users > I select the plus button to add to specific column and that is when the error occurs.
Is this doable, or is something amiss?
Thank you for your help.
you should not be using the authenticate user behavior for this, that is only used on the login page.
your stare rating widget should have a setting to make the rating read only, you would need to add the Security Assist -> Show region behavior around that code to have it used on the page if the user is not logged in.
johna1964
Ok. Thank you much!
