trying to upload
Thread begun 11/26/2013 9:15 am by Jamie | Last modified 11/26/2013 11:22 am by Jason Byrnes | 3175 views | 7 replies |
Jamie
trying to upload
hey Jason
have been trying to get the attached update page to update the relevant Image column in the db and upload the image file to the server but it is doing neither. its not affecting the existing record at all.
Any advice gratefully recieved.
Cheers
Jamie
to troubleshoot, make sure that page does not redirect after performing the upload, then add the following code at line 1 to turn on error reporting:
error_reporting(E_ALL);
then open the bindings panel, and expand the uploaded files global status, add the debug info binding to your page.
then add the following code before the closing body tag:
<?php var_dump($_FILES); ?>
post back the results after testing the upload again,
Jamie
here you go Jason - it seems I made a mistake, it is in fact uploading the file but its not updating the db record.
Status object: WA_UploadResult1
statusCode : 1
errorMessage :
clientFileName : motley-007.jpg
fileExtension : jpg
serverFileName : motley-007_2.jpg
serverSimpleFileName : motley-007_2
serverDirectory : /home/motle8wh/public_html/clients/binder/admin_cms/../images/slideshow/CTA/
contentType : image/jpeg
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed : 1
fileSize : 28392
isImage : 1
imageWidth : 700
imageHeight : 466
WA_UploadResult1_1:
fileExtension : jpg
fileSize : 28392
imageWidth : 700
imageHeight : 466
isImage : 1
fileWasSkipped :
fileWasRenamed : 1
statusCode : 1
array(1) { ["Image"]=> array(5) { ["name"]=> string(14) "motley-007.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(14) "/tmp/phpTt7VRj" ["error"]=> int(0) ["size"]=> int(142205) } }
see PM
Jamie
thanks see PM
in the update behavior, the ID value is coming from the WADAUpdateRecordID form element, this form element:
<input type="hidden" name="WADAUpdateRecordID" id="WADAUpdateRecordID" value="<?php echo((isset($_GET["invalid"])?ValidatedField("slideshowctaupdate","WADAUpdateRecordID"):$_GET["SlideshowCTAID"])); ?>" />
is set to use a variable that does not exist, SlideshowCTAID. chamnge it to use the ID variable:
<input type="hidden" name="WADAUpdateRecordID" id="WADAUpdateRecordID" value="<?php echo((isset($_GET["invalid"])?ValidatedField("slideshowctaupdate","WADAUpdateRecordID"):$_GET["ID"])); ?>" />
Jamie
thank you Jason
you're welcome.
