Powerstore 4 Menu
Thread begun 11/25/2013 10:50 am by rob294118 | Last modified 11/25/2013 11:39 am by Jason Byrnes | 1102 views | 1 replies |
rob294118
Powerstore 4 Menu
I removed the Support Pages from the menu using the Admin backend. The menu items did not get removed and are now blank. How do I fix this? Where is the menu.php file located?
the menu is generated by the webassist/plugins/main_menu/menu.php file.
you will need to remove the custom menu section:
<li class="parent top"><span><a href="../../../page.php?Custom Menu=1">
<?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Custom Menu', 'Menu Label', true); ?></a></span>
<ul class="level-1">
echo($WACustomPages->Body);
</ul>
</li>
