Activation error
Thread began 8/18/2009 10:57 am by atjami321930 | Last modified 8/18/2009 11:21 am by Jimmy Wu | 1173 views | 1 replies |
atjami321930
Activation error
I downloaded the current version of DataAssist in my accounts area and now I get this error when I put in my serial number. I can't disable my firewall. Can you assist me?
Error message:
Unable to contect to the server even after disabling the fire/antivirus. Please aciviate it manually.
Thanks,
AJ
Jimmy Wu
When you activate our software, it will need to connect to our servers to generate the license file. This file is generated based on the serial number of the software that you are activating, and the MAC or Physical address of the computer that you you are activating it on. If you are not able to disable the firewall, I can generate the license file for you. I will need the serial number that you are using to activate the software with. I will also need the MAC address from your computer. To find out the MAC address:
1) Go to the Start Menu -> Run. Type "cmd" and click on OK to bring up a command prompt.
2) At the command prompt type "ipconfig /all > c:\\ipconfig.txt"
This will create a file in your C drive called ipconfig.txt. This file will have the MAC address in it. Please send that file with you serial number and I will generate the license for you.
I have created a support ticket for you, please send the files through the private ticket. You can check your ticket by visiting your support history:
