error in ecart 4
Thread begun 11/21/2013 2:56 pm by randyw2394710 | Last modified 11/22/2013 8:14 am by Jason Byrnes | 1150 views | 1 replies |
randyw2394710
error in ecart 4
ecart 4
when i try to select record error 1 set or id column error 2
im getting these errors this happens when i try to add an add to cart button
eCart 4 is not supported in DW CS 6. You would need to upgrade to eCart 5 in order to use eCart in DW CS 6.
to be able to use eCart 4, you will need to continue using the previous DW Version you had.
