Wrong Template Location in Theme
Thread begun 11/21/2013 3:25 am by Daryl | Last modified 11/21/2013 6:15 am by Jason Byrnes | 1625 views | 1 replies |
DarylBeta Tester
I have created a theme from template, however the link to the template file in the include is incorrect.
the code generated is;
new WA_Include("../Templates{$WA_admin_1385028655674_Content_Empty}/admin.dwt.php");
the code should be;
new WA_Include("../templates{$WA_admin_1385028655674_Content_Empty}/admin.dwt.php");
Where can I edit this code centrally so that I don't have to change it for each page that I build using a theme?
The Template folder created by Dreamweaver should have a capitol T not lower case. It should be correct with the Capitol T. It would be best to use the Capitol T for the template folder as that is the Norm that DW uses.
