Clearing a session help
Thread begun 11/18/2013 7:05 am by iainmacdonald331081 | Last modified 11/18/2013 12:26 pm by Jason Byrnes | 3437 views | 5 replies |
iainmacdonald331081
Hopefully this is a straightforward one.
I have a page that lists some lodges here:
http://lodges.goodsafariguide.com/botswana/
If you click on any of them, a Session is started which stores the LodgeID, which is used for a Query on a Nominations table.
So if you click on African Horseback Safaris and scroll down, it lists two nominations:
2013 Best Riding Safari Operator
2011 Best Riding Safari Operator
So that's all fine.
But if you go back and click on another lodge, it will show those two Nominations again. But will update if you refresh the page.
I basically just have a clear session before a start session - see PM below.
iainmacdonald331081
Code below..
Should it be possible for that to update without having to refresh the page?
it depends on where in the code the session is cleared, try adding the clear session code at line 1.
iainmacdonald331081
Thanks Jason. That was the one thing I already thought to try, but when I moved it to the top of the page it was starting the session, so no Nominations were being displayed.
I've attached the page for reference.
iainmacdonald331081
Played around with practically every different way of ordering it, and seem to have it working with the code in the order below, just above the Nominations query.
glad to hear it is working.
