Digital File Pro not working !!!!
Thread begun 8/18/2009 9:28 am by rob75685 | Last modified 8/18/2009 12:17 pm by Ray Borduin | 4500 views | 10 replies |
rob75685
Another WA problem - been most of the day on this one.
When using Digital File Pro on my Update page it is not updating the Default file field... just ends up blank whatever I put in...
useless, now behind schedule and spending precious time trying to get your software to work... again !
What version do you have installed? We had this issue in an early build, but I believe it has been addressed in the most recent version available in your order history. Do you have this problem with the current build? If so then we will need to debug the cause further, but an update of the software may do the trick.
rob75685
hi Ray
Thanks for your quick reply, and apologies for my rant - had a very slow day.
I'm using the latest version - 2.01
Alternatively can you give me the php to fit in here:
'DefaultFileName' => ".........",
thanks
The code in there would either be a reference to the hidden form element you placed on the page and put the current file name into, or it could be a reference to the recordset and file name column directly (but make sure your recordset is filtered properly).
Using a hidden form element may be the easier way to debug even though it takes more steps sometimes people fall down trying to keep the update recordset on the correct row after the update button is submitted which can make the direct recordset reference a little trickier to debug when you have issues.
rob75685
hi Ray
I have no idea what to put in here... yes I've added a hidden form field but DFP won't let me put anything in the Default file field
IS there any way you can do it your end with a dummy field and send me the resulting code please ?
Change focus into another field after updating the default file field and it should take the update.
Referring to the hidden field is the right solution. It will result in code similar to:
'DefaultFileName' => "" .(isset($_POST['HidFieldName'])?$_POST['HidFieldName']:""). "",
rob75685
hi
No changing focus makes no difference... if I go back a step then forward it's even empty then
trying your code now, thanks
What DW version and OS are you using? I'll have someone try to reproduce the problem with a similar system to see if there is a bug we can fix.
rob75685
hi Ray
Your code:
worked - thank you!
My system is: OSX 10.5.8, Dreamweaver CS3 (9)
rob75685
DFP Delete not working either
Digital File Pro - Delete file doesn't work either... just doesn't remove the file
I've double checked all the settings and they are correct...
