uploading to a directory depending user login
Thread begun 11/16/2013 12:33 pm by balexander389215 | Last modified 12/02/2013 6:47 am by Jason Byrnes | 8316 views | 20 replies |
balexander389215
I have added a script to the Registration page that automatically creates a directory using the users login name. Is there any way to link this directory to file upload so that when a user logs in in and uploads files it will automatically go to their directory?
save that name as a session variable, then bind the upload folder to the session variable.
balexander389215
Thank you but I'm not sure I know what you mean or more specifically how to do that. How do I save the database field as a session variable and how would I use that in DFPro?
thanks for your continuing support.
on the login page, open the server behaviors panel, and double click the security assist authenticate user behavior. go to the Session tab. Click the plus button and select the username column, this will save the username to a session.
on the page that you add the upload file behavior to, click the lightning bolt icon next to upload folder, and select the session created by the login page.
balexander389215
Thank you for your help. It is almost but not quite working. On the site I have a directory named author, inside that directory is another directory, author_files. It is in this directory that a new directory is automatically created with new registration using the username as the directory name. I followed your suggestions and what now happens is that uploaded files are going the the first, author directory. As I said, almost there. Do you have any input on what I might be doing wrong?
Brian
you have a number of different upload behaviors on this page and they are all set incorrectly.
In the upload folder, click the lightning bolt, and select the username session variable, this will add the following code:
<?php echo $_SESSION['username']; ?>
assuming the session is named username, it may look slightly different if your session uses a different name.
preface the auther/auther_files directory in front of that:
author/author_files/<?php echo $_SESSION['username']; ?>
NOTE: on pages that use a session, you may need to add the following code at line 1:
<?php @session_start(); ?>
balexander389215
The reason for all the different upload behaviors is I kept trying different things to get it to work.
I tried it again from scratch. Created the session ID named username on the login page. Then I created a new form uploader.php went through the file upload wizard and added directory path and session variable as above. All the files still go into the main author directory. I even added a username directory into the author directory but no luck. Then I realized I missed the session start on line one of the uploader.php file, added it, uploaded to the site and retried. Still no luck. Should the author/author_files directory be an absolute path, ie., home/author/... or something like that.
I also uploaded the helperphp.php file, are there any other files that should have been uploaded?
Nope, I just tried changing the path to the absolute path and still the same results, the uploaded files go directly into the author directory. Perhaps what I want is not possible?
The file you sent has a few probelms to it
of the 5 upload file behavior you have in place, only one of them has the upload folder set to the author/author_files folder. for testing it would be best to start with only one file upload in order to track the results.
you have a few file fields that use the same name. This is not valid. each form element must use a unique name.
the multiple upload behaviors and reusing the same name are going to cause skewed results.
balexander389215
I started over with a simple form and only one upload field. The end result is the same, files are still only going into the author directory.
