Installed menu writer second computer, could seamless transition should hard drive crash presets second computer Help thanks
Thread begun 11/15/2013 12:38 pm by john195272 | Last modified 2/17/2014 2:02 pm by Jason Byrnes | 1919 views | 5 replies |
john195272
Menu writer not showing content or themes on the second computer where I installed menu writer. Also the little gold tag...not there.
you need to use the preset manager:
Window -> Preset manager
to export the content and theme presets from the original computer to the new computer.
also, in the DW Preferences, go to the Hidden Elements tab and select scripts.
john195272
Finally....Went to DW Preferences...still not seeing the Edit Contents or the Edit Theme choices...just the menu writer
Jason, still an issue seeing all the choices, all I have is the Menu Writer choice showing.
I finally got around to going into Preferences and the Invisible Elements (is what they called it in my version vs. hidden) the script box was already selected. Did this per your instructions. Any other ideas, I would really need this backup to work seamlessly if possible. Thanks!
"all I have is the Menu Writer choice showing. "
Yes, that is correct, you will only have that option, you can select to edit contents or themes in the menu writer edit dialog
john195272
Thanks Jason
Thanks you sir for your outstanding service!!!!!!!!!!!!!!
you're welcome.
