minimum quantity question
Thread begun 11/15/2013 12:17 pm by elewis93815 | Last modified 11/18/2013 8:25 am by Jason Byrnes | 3056 views | 3 replies |
elewis93815
I believe I have added a minimum quantity ordering rule on this page but it seems customers can change their quantity??? Any direction is appreciated.
how did you implement the minimum quantity?
the way i would suggest implementing a minimum quantity is to have a cart column name minQuantity where you set the minimum. In the add to cart button behavior, set the value for the minimum quantity column then create a calculation as:
abs([Quantity] < [minQuantity])?[Quantity] = [minQuantity]:''
this will prevent users from setting the quantity to be below the minimum you set.
elewis93815
On line 497-509 for one and 456-465. Would I need to redo the add to cart buttons or can I add the code itself for the additional column?
using validation like this only forces the quantity when it is initially set, once added to the cart, it does not prevent the quantity being changed.
the method i outlined above will prevent the quantity being changed.
you will need to edit the add to cart button behaviors to make the change.
