Data Bridge Serial Number
Thread begun 11/15/2013 6:30 am by gary917 | Last modified 1/06/2014 1:24 pm by Jason Byrnes | 3446 views | 4 replies |
gary917
Hi, I was wondering why I have to constantly reset my serial number in Data Bridge and Design Extender.
the activations is based on the Physical (or MAC) address of the active network card.
If you switch between a wireless and a hard wired connection, each connection type has it's own MAC address, so will require reactivation.
This can also happen if you have VPN Software installed that creates a virtual network connection. The virtual network connection will constantly change the MAC Address and cause the reactivation
gary917
I guess it looks like my Blackberry's VPN is causing this to happen. I have recently been have problems with it as it keeps crashing.
paulshoe379536
It seems like I am also having this happen lately. Seems like it's when I restart Dreamweaver or may after I reboot. I am running on Windows 7 and not through VPN.
VPN Is only one example of how the MAC Address may change.
to check the mac Address on Windows, go to the command prompt and type:
ipconfig /all
check the mac address for the first active connection and make note of it.
next time you restart, run the ipconfig command again to make sure it is not changing.
