Better understaning how Dataassist builds queries
Thread begun 11/15/2013 5:31 am by sysop349733 | Last modified 11/15/2013 9:55 am by sysop349733 | 2786 views | 4 replies |
sysop349733
I'm trying to better understand how DataAssist builds queries so that I can tweak and refine them in the PHP code.
DataAssist makes something like this:
$query_WADAtable = "SELECT field1, field2, FROM table a, history b WHERE field1=field2
setQueryBuilderSource($query_WADAtable,$WADbSearch1,false);
$query_limit_WADAtable = sprintf("%s LIMIT %d, %d", $query_WADAvoters, $startRow_WADAvoters, $maxRows_WADAvoters);
Elsewhere, there is something like this:
$WADbSearch1->addComparisonFromEdit("registr_date","registr_date","AND",">=",2);
$WADbSearch1->addComparisonFromEdit("municipality_abbrv","municipality_abbrv","AND","=",0);
How is "addComparisonFromEdit" added to the query? Is it added as part of the WHERE clause? In any particular order?
Is there some documentation that explains what's happening? (I'm also interested in understanding the parameters for setQueryBuilderSource and addComparisonFrom.)
Thanks in advance.
the setQueryBuilderSource function pareses the criteria that are set by the addComparisonFromEdit and adds to the where clause if needed.
the following comparison:
would add to the where clause if the registr_date form element from the search where filed in and look for an entered date in the data base greater than the one entered.
It would be added after the existing where clause
sysop349733
That is precisely what I needed to know. Thank you. What do the numerical params in addComparison control?
data type, it is really only used to mark a column as a date (2) or not.
sysop349733
OK, great! Thanks again.
