ecart check out wizard crashes
Dreamweaver CS3, Windows XP, items in my SQL database. Shopping cart works fine. Check out wizard crashed DW. Can't get past selecting database. HELP!
please provide some more details.
are you getting an error message? if so what is the error?
What version of eCart?
What other extensions are installed, including the version numbers?
Try reseting the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
Then close DW and Delete the Dreamweaver Cache file from the users configuration folder:
Next open the extension manager, and uninstall eCart, then reinstall it.
